Trouble connecting to SPI display sh1106
dakschnitzer
Post by dakschnitzer » Thu Aug 08, 2019 12:58 am
I was able to get external OLED displays working with a Heltec wifi ESP8266 over SPI with SH1106 as follows:
from machine import I2C, Pin, SPI
oled_reset_pin = Pin(16, Pin.OUT)
spi = SPI(1, baudrate=800000)
display = sh1106.SH1106_SPI(128, 64, spi, dc=Pin(0), res=oled_reset_pin, cs=Pin(15))
display2 = sh1106.SH1106_SPI(128, 64, spi, dc=Pin(2), res=oled_reset_pin, cs=Pin(1))
I've been trying to get it work with the Heltec wifi ESP32 and have not been able to figure it out! The pinout diagram is here: https://github.com/dakschnitzer/time-gu ... t%2032.pdf
I have the SPI display connected to the ESP32 as follows, but I get nothing on the display:
CLK -> GPIO18 (SCK / V_SPI_CLK)
MOSI -> GPIO23 (MOSI / V_SPI_D)
RES -> GPIO16 (OLED_RST)
DC -> GPIO26 (no idea where this should go)
CS -> GPIO5 (V_SPI_CSO)
Please let me know if I am doing something wrong here. The code I'm trying to run on the esp32 to goet this to work is:
import sh1106
oled_reset_pin.value(1)
spi = SPI(1, baudrate=8000000)
display = sh1106.SH1106_SPI(128, 64, spi, dc=Pin(26), res=oled_reset_pin, cs=Pin(5))
I'm using this sh1106 driver: https://github.com/robert-hh/SH1106/blo ... /sh1106.py
Re: Trouble connecting to SPI display sh1106
Post by jimmo » Thu Aug 08, 2019 11:29 am
Can you clarify what you mean by "(no idea where this should go)"
By the looks of that diagram, the OLED is connected by I2C, not SPI?
So instead:
import sh1106
i2c = I2C(sda=Pin(4), scl=Pin(15))
display = sh1106.SH1106_I2C(128, 64, i2c, res=Pin(16))
dakschnitzer
Post by dakschnitzer » Sun Aug 11, 2019 8:53 pm
Thanks for the reply.
As mentioned, I've gotten the external displays to work with an esp8266 using the code I pasted in. They are SPI displays, not I2C. The OLED display that is internal to the Heltec ESP32 board is I2C, and that works fine.
Here's the external SPI display I'm using: https://www.amazon.com/dp/B07QD4JWCN/re ... 6Cb749ZDMW
The comment I wrote about the DC pin on the SPI display is that I do not understand which pinout of the Heltec ESP32 I should be using for DC. I was guessing that perhaps GPIO26 would work. I was fairly confident that I had selected the correct GPIO pins for the other pins necessary for SPI displays as follows:
So my questions are:
1. Have I selected the correct GPIO pins for the CLK, MOSI, RES, and CS pin on the SPI display?
2. What GPIO pin should I select on the ESP32 for the DC pin on the SPI display? I'm guessing GPIO26 should work but the display isn't showing anything.
3. Am I doing something else wrong?
As mentioned, I've gotten these SPI displays to work on the Heltec wifi ESP8266.
rpr
Post by rpr » Sun Aug 11, 2019 11:31 pm
I don't have this board and have not used the SPI as well so my response may be naive. From the docs it appears that VSPI is at SPI(2).
http://docs.micropython.org/en/latest/e ... re-spi-bus
Post by OutoftheBOTS_ » Mon Aug 12, 2019 6:39 am
The on board OLED on the Heltec wifi ESP32 appear to be connect via I2C. https://github.com/dakschnitzer/time-gu ... t%2032.pdf
These little OLED can be wired many ways: I2C, SPI 3 wire, SPI 4, 8 bit parallel or even 16 bit parallel.
The low res of the OLED coupled with the fact it is only 1 bit colour means the speed of coms isn't an issue so it isn't uncommon to connect via I2C for these to save on pins used
dakschnitzer
Post by dakschnitzer » Mon Aug 12, 2019 5:00 pm
Yes, the i2C OLED on the board itself is working fine. I'm not asking about how this works.
My question here is about getting this external SPI display working with the Heltec esp32: https://www.amazon.com/dp/B07QD4JWCN/re ... 6Cb749ZDMW
As you can see, this is a SPI display. As mentioned, I got these SPI displays to work fine over SPI using the aformentioned sh1106 SPI driver on the Heltec esp8266 board.
I'm now trying to get them to work on the esp32 board and am having trouble.
If anyone has successfully gotten external SPI displays to work on the Heltec esp32, I'd love to know what pins they're using. Especially for DC. As previously linked, the Heltec esp32 pinout pretty clearly shows what pins should be used for the other SPI pins - CLK, MOSI, RES, and CS.
I'm confused about which pin to use for DC.
Thanks,
Dan
Post by Roberthh » Mon Aug 12, 2019 5:22 pm
You can use any pin which is not used otherwise and that can be used in output mode. So do NOT use for thatGPIO0, GPIO1, GPIO3, GPIO34-39, and GPIO19. The latter is used for the hardware SPI 2 MISO, which you seem to use. For SPI 2, you have to chage you code into:
spi = SPI(2, baudrate=8000000)
see: http://docs.micropython.org/en/latest/e ... re-spi-bus
dakschnitzer
Post by dakschnitzer » Tue Aug 13, 2019 3:53 pm
Thanks for following up! I'll give this a try.
Can you clarify what baudrate to use? I'd been using 800,000; you wrote 8,000,000; and in the documentation you linked to it's 80,000,000!
Thanks,
Dan
Post by Roberthh » Tue Aug 13, 2019 4:13 pm
The data sheet of the SH1106 talks a minimum clock cycle of 250 ns. That's a 4 MHz clock.
In a ESP8266 script I used 10 MHz. But the final clock rate was lower. The hardware SPI should make a more precise clock, so better do not use values beyond 4 MHz. In the samples of my driver I use 1 MHz.
P.S.: I copied the line from your script w/o checking, whether the clock is good.
dakschnitzer
Post by dakschnitzer » Tue Aug 20, 2019 3:48 am
Thanks so much, Robert! Inserting the hspi initialization worked like a charm after changing around the pinouts.
