SSL ESP32
tcpipchip
SSL ESP32
Post by tcpipchip » Wed Aug 21, 2019 1:45 pm
import ssl
import socket
s = socket(socket.AF_INET, socket.SOCK_STREAM, socket.IPPROTO_SEC)
>>> import socket
>>> import ssl
AttributeError: 'module' object has no attribute 'IPPROTO_SEC'
Can you help me ?
I want a easy method to access aws iot (i have the certicates..in other post i showed the problem with mqtt, now i will try "socket"
not easy!
Works for you ?
Online
Re: SSL ESP32
Post by jimmo » Thu Aug 22, 2019 12:24 am
I think the documentation you're looking at might be out of date (e.g. from v1.9) or possibly specific to the WiPy board. I don't believe this parameter is required anymore.
Have a look at
https://docs.micropython.org/en/latest/ ... rap_socket
And an example using ussl.wrap_socket https://github.com/micropython/micropyt ... request.py
