How to Convert .py to .mpy for ESP32
AmirJ
Post by AmirJ » Sat Sep 07, 2019 5:37 am
hi
I need to compiled micropython file to run by ESP32. (To ensure manipulation and security.)
Re: How to Convert .py to .mpy for ESP32
Post by jimmo » Sat Sep 07, 2019 6:16 am
You need to use mpy-cross, which you can either build from source (make sure you checkout at the same version tag as your firmware), or the much easier option is to install using pip (see https://pypi.org/project/mpy-cross/ )
Post by Roberthh » Sat Sep 07, 2019 6:27 am
Use mpy-cross on the PC to compile you .py files into .mpy files. I have a few compiled versions here: https://github.com/robert-hh/Shared-Stuff. Other people share that too. A search on the board will reveal it.
AmirJ
Post by AmirJ » Sat Sep 07, 2019 2:03 pm
Good
Thank you
It works.
mattyt
Post by mattyt » Sat Sep 07, 2019 2:32 pm
mpy-cross is also pip-installable (thanks AndrewL!):
