upip installs libraries located on PyPi (
https://pypi.org/) or in a special repository for the MicroPython library. The micropython-tinyrtc-i2c package doesn't seem to exist on PyPi. To install it you need to copy the program files from the GitHub archive to your device. To clone the GitHub library to your PC issue
git clone https://github.com/mcauser/micropython-tinyrtc-i2c.git
From your PC you can then copy the Python files to your hardware using whatever IDE you are using or a command line tool like
rshell.
