I would like to connect an ESP32 to a server hosting the webpage ‘example.com’. I am using an Adafruit HUZZAH32 and Thonny IDE.
Thanks!
Get a webpage with ESP32
Re: Get a webpage with ESP32
Are you using CircuitPython or MicroPython.
The easiest way to do this is with urequests. On MicroPython for ESP32, this is included in the default firmware. It works a lot like the Python "requests" library.
On CircuitPython, take a look at https://circuitpython.readthedocs.io/pr ... t/api.html
import urequests
r = requests.get("http://example.com/")
# Use one of these depending on what your response looks like:
print(r.content)
print(r.text)
print(r.json())
r.close()
I presume I can connect to my network, then call this?
Yes, micro python for ESP32.
Yes, use the instructions here http://docs.micropython.org/en/latest/e ... networking for connecting to the network first.
