Hi there,
at the moment I'm trying to flush several hundred bytes (JSON) to a btree database. The first flush at startup after db initialisation is working fine all following flushes are leading to an guru meditation error. When I avoid flushing, i can use the db without any problems but after a reset everything is gone...
At first i had opened the db at startup and made my calls against the open handle. Then I tried to open the db and file handles on every operations but nothing worked so far.
Has anybody experienced the same behavior or even has a solution for this problem?
Thx!
Best!
