I wanted to connect to a WPA2 EAP network (Eduroam) and found that micropython could not Because I was able to from C I knew I could write a new function into the network library to set up WPA EAP.
Right now my function is definitely a very dirty hack as I don't bother checking the types of the mp_objects I also don't know what sort of state information might be worth saving.
I will most the code for the function when I get home. While I would definitely not want to put that function into micropython as it stands it could start as a base for someone who knows their way around micropython's internals more.
Support for WPA2 EAP networks.
Re: Support for WPA2 EAP networks.
//Set up EAP
STATIC mp_obj_t esp_seteap(mp_obj_t self_in,mp_obj_t username,mp_obj_t password){
size_t Ilen;
size_t Plen;
const char *EAP_IDENTITY = mp_obj_str_get_data(username,&Ilen);
const char *EAP_PASSWORD = mp_obj_str_get_data(password,&Plen);
ESP_EXCEPTIONS(esp_wifi_sta_wpa2_ent_set_identity((uint8_t *)EAP_IDENTITY, strlen(EAP_IDENTITY)));
ESP_EXCEPTIONS(esp_wifi_sta_wpa2_ent_set_username((uint8_t *)EAP_IDENTITY, strlen(EAP_IDENTITY)));
//ESP_EXCEPTIONS(esp_wifi_sta_wpa2_ent_set_new_password((uint8_t *)EAP_PASSWORD, strlen(EAP_PASSWORD)));
ESP_EXCEPTIONS(esp_wifi_sta_wpa2_ent_set_password((uint8_t *)EAP_PASSWORD, strlen(EAP_PASSWORD)));
ESP_EXCEPTIONS(esp_wifi_sta_wpa2_ent_enable());
return mp_const_none;
STATIC MP_DEFINE_CONST_FUN_OBJ_3(esp_seteap_obj, esp_seteap);
{ MP_ROM_QSTR(MP_QSTR_seteap), MP_ROM_PTR(&esp_seteap_obj) },
It makes a new function that takes your username and password that are used for connecting. I am not sure exactly when you would call it to connect but I have had success calling it both before and after activating the interface but always before trying to connect.
Want to bring attention back up to this. As adding PEAP support would help micropython be used in some academic environments more easily.
Also I would submit a PR but I don't know how to add the proper checks around the inputs yet.
We have a project in development that is now required to have WPA2-Enterprise encryption.
I see the Arduino, Pycom and CircuitPython have this ability.
Has anyone ever seen a library available for micropython?
This is required for most commercial networks and I would hope that micropython would including this connectivity.
- 2020-10-07 16_01_50-adafruit_esp32spi — Adafruit ESP32SPI Library 1.0 documentation.png (47.35 KiB) Viewed 5223 times
Unfortunately no library exists. I was going to try and make a library using the new features that allow C modules to be compiled as libraries but unfortunately they can't use ESP IDF functions not defined in the one table. So your stuck with modifying Micropython itself.
In a previews build (v4.0?) we were able to build using chbill modifications to the modnetwork.c
file and were able to connect using a username and password pair without a certificate.
But are getting build errors....
Not at all proficient with C and help would be appreciated!!
PYCOM has the ability to connect to Enterprise networks...
https://docs.pycom.io/tutorials/network ... se-network
scroll down to... Connecting to a WPA2-Enterprise network
They have the ability to connect using (or not using) CA certificates.
QUESTION....
Does micropython have plans in adding WPA2-Enterprise support any time soon ???
We are now trying to build using... esp-idf v4.2, lv_micropython dev using micropython v1.14.
o-old-style-declaration -D_GNU_SOURCE -DIDF_VER=\"v4.2\" -DLV_KCONFIG_IGNORE -DLV_COLOR_DEPTH=16 -DLV_COLOR_16_SWAP=1 -DESP_PLATFORM -Wno-clobbered -Wno-deprecated-declarations -Wno-missing-field-initializers -MD -MT esp-idf/main/CMakeFiles/__idf_main.dir/__/modnetwork.c.obj -MF esp-idf/main/CMakeFiles/__idf_main.dir/__/modnetwork.c.obj.d -o esp-idf/main/CMakeFiles/__idf_main.dir/__/modnetwork.c.obj -c ../modnetwork.c
../modnetwork.c: In function 'esp_seteap':
../modnetwork.c:379:20: error: implicit declaration of function 'esp_wifi_sta_wpa2_ent_set_identity'; did you mean 'esp_wifi_sta_get_ap_info'? [-Werror=implicit-function-declaration]
ESP_EXCEPTIONS(esp_wifi_sta_wpa2_ent_set_identity((uint8_t *)EAP_IDENTITY, strlen(EAP_IDENTITY))); // identity==username
../modnetwork.c:116:47: note: in definition of macro 'ESP_EXCEPTIONS'
#define ESP_EXCEPTIONS(x) do { esp_exceptions(x); } while (0);
../modnetwork.c:380:20: error: implicit declaration of function 'esp_wifi_sta_wpa2_ent_set_username'; did you mean 'esp_wifi_set_storage'? [-Werror=implicit-function-declaration]
../modnetwork.c:382:20: error: implicit declaration of function 'esp_wifi_sta_wpa2_ent_set_password'; did you mean 'esp_wifi_set_max_tx_power'? [-Werror=implicit-function-declaration]
../modnetwork.c:383:20: error: implicit declaration of function 'esp_wifi_sta_wpa2_ent_enable'; did you mean 'esp_wifi_set_event_mask'? [-Werror=implicit-function-declaration]
cc1: some warnings being treated as errors
[1241/1371] Building C object esp-idf/main/CMakeFiles/__idf_main.dir/__/mpthreadport.c.obj
ninja: build stopped: subcommand failed.
ninja failed with exit code 1
make: *** [Makefile:24: all] Error 2
make: Leaving directory '/home/rich/2021-Frimware/lv_micropython/ports/esp32'
QUESTION....
Okay so I found that for some reason I can't include "esp_wpa2.h" which has to be included for this to work. For some reason CMake can't find the file thats inside of the ESP-IDF.
I am going to hunt around and figure it out, I will even move those files to the build path maybe if I have to.
Did you get this to work
