when i reboot my esp32, in the REPL it shows the error mentioned in the title. when i was following the tutorial to "getting started" with uPython on the esp32, i didnt notice anything that mentioned a "menu config". how would i go about accessing this menu, and changing the configured chip revision?
if it is important, this is the name of the firmware that i flashed to the esp32:
esp32-idf3-20191122-v1.11-586-g1530fda9c.bin
dps
W (201) cpu_start: Chip revision is higher than the one configured in menuconfig. Suggest to upgrade it.
Re: W (201) cpu_start: Chip revision is higher than the one configured in menuconfig. Suggest to upgrade it.
This is just an informative warning, safe to ignore.
Menuconfig is part of the SDK that you use when writing ESP32 firmware in C. If you want to provide a custom board config for MicroPython, you can override this setting (Tinypico does this for example)
OH! ok, i think i remember seeing somewhere now. like when compiling a custom Linux kernel, you (eventually) use `make menuconfig`.
thanks!
thanks!
