All ESP32 chips have a built-in hall effect sensor, used to measure a prevailing magnetic field.
As I understand things, it is inherent to the chip itself and is not a peripheral, so presumably the field must be local to the chip.
In the Arduino IDE, I am told, it is straightforward to measure the output of the hall effect sensor using a dedicated 'HallRead()' function.
I haven't been able to find any mention of it in the MicroPython docs or with some dedicated Googling around.
Does MicroPython support it?
Thanks,
Brian H.
Hall Effect sensor?
Re: Hall Effect sensor?
Hello
Taken from http://docs.micropython.org/en/latest/e ... ckref.html
Regards Mike
esp32.hall_sensor() # read the internal hall sensor
Regards Mike
I believe the sensor is not very sensitive. For accurate measurements you're best off with an IMU device (inertial measurement unit), which will actually supply a vector - obviously at some cost in money and complexity.
Drivers for various devices are available on this site.
Not all IMUs have a hall sensor I think? But depends on what the topic starter wants to do; if it's really about measuring magnetic field values then money might be better spent on a dedicated and calibrated sensor instead of paying extra for the unused features in an IMU.
Fair point: you need a 9DOF IMU. It's possible that the high production volumes of IMU's make them cost effective compared to dedicated magnetometers but I haven't investigated. The other advantage is that drivers exist. Devices like the MPU9250 produce a vector in units of μT. The driver enables the magnetometer to be calibrated by the usual method of rotation.
Seeing prices in the range of 10$: yes it's going to be hard to beat that. I only briefly checked the specs but it seems something like an MPU9250 doesn't come with a dedicated temperature sensor along with the hall sensor so getting accurate absolute values out of it is not possible. Then again, for pure hobby projects and/or with the chip always running at roughly the same temperature this is normally not needed.
Thanks.DJShadow1966 wrote: ↑Sat Dec 21, 2019 6:28 amHello
Taken from http://docs.micropython.org/en/latest/e ... ckref.htmlCode: Select all
Regards Mike
