ADXL345 range setting on micropython
davidbogatec
Post by davidbogatec » Tue Feb 04, 2020 3:33 pm
I want to set the 16g range of the accelerometer. The default range is 2G. Where I need to specify this in the below code?
from machine import Pin,I2C
import math
device = const(0x53)
regAddress = const(0x32)
TO_READ = 6
buff = bytearray(6)
class ADXL345:
    def __init__(self,i2c,addr=device):
        self.addr = addr
        self.i2c = i2c
        b = bytearray(1)
        b[0] = 0
        self.i2c.writeto_mem(self.addr,0x2d,b)
        b[0] = 16
        b[0] = 8
    @property
    def xValue(self):
        buff = self.i2c.readfrom_mem(self.addr,regAddress,TO_READ)
        x = (int(buff[1]) << 8) | buff[0]
        if x > 32767:
            x -= 65536
        return x
    @property
    def yValue(self):
        y = (int(buff[3]) << 8) | buff[2]
        if y > 32767:
            y -= 65536
        return y
    @property
    def zValue(self):
        z = (int(buff[5]) << 8) | buff[4]
        if z > 32767:
            z -= 65536
        return z
    def RP_calculate(self,x,y,z):
        roll = math.atan2(y , z) * 57.3
        pitch = math.atan2((- x) , math.sqrt(y * y + z * z)) * 57.3
        return roll,pitch
cgglzpy
Re: ADXL345 range setting on micropython
Post by cgglzpy » Tue Feb 04, 2020 6:38 pm
You can see this in the data sheet: ADXL345
[Page 26-27] Register 0x31—DATA_FORMAT (Read/Write) --> Range Bits D1-D0
So you need to write to register 0x31 the byte 0x03 which is 0b00000011 (see Table 21) setting bits D1-D0 to 1.
In code should be something like:
reg_DATA_FORMAT = const(0x31)
and inside 'def __init__' method add:
b[0] = 3
self.i2c.writeto_mem(self.addr,reg_DATA_FORMAT,b)
I can't test this but I think this is the way.
davidbogatec
Post by davidbogatec » Wed Feb 05, 2020 8:46 am
Hi cgglpzy and thanks for your prompt reply.
i've insert the suggested lines in the code but nothing happens.
Where is the error?
import math
TO_READ = 6
buff = bytearray(6)
class ADXL345:
self.addr = addr
self.i2c = i2c
b = bytearray(1)
b[0] = 0
b[0] = 16
b[0] = 8
b[0] = 3
b)
@property
def xValue(self):
if x > 32767:
x -= 65536
return x
@property
def yValue(self):
if y > 32767:
y -= 65536
return y
@property
def zValue(self):
if z > 32767:
z -= 65536
return z
return roll,pitch
cgglzpy
Post by cgglzpy » Thu Feb 06, 2020 3:58 pm
Hmm, maybe because of this
From the data sheet Page 26:
All data, except that for the ±16 g range, must be clipped to avoid rollover
So I think you have to comment or erase the "if x > 32767" lines.
Something like this:
def xValue(self):
    # if x > 32767: # These two lines is to "clip" the data to avoid rollover
    #     x -= 65536 # They are necessary for ranges 2g-8g but not for 16g range
    return x
Also do the same with yValue and zValue methods.
If this does not solve it then I don't know what can it be :?
