invalid trigger behavior
Posted: Fri Feb 07, 2020 11:56 pm
I have some interrupt trigger testing code which doesn't work properly:
The code prints the pin for both falling and raising events, i.e. both when I connect the pin 12 to GND and when I disconnect it.
Can someone check this small bit of code out, please?
BTW: I have tried using different pins without success.
REPL says I am using:
MicroPython v1.12 on 2019-12-20; ESP32 module with ESP32
from time import sleep
interrupt_pin = None
def handle_interrupt(pin):
global interrupt_pin
interrupt_pin = pin
pin = Pin(12, mode=Pin.IN, pull=Pin.PULL_UP)
pin.irq(trigger=Pin.IRQ_FALLING, handler=handle_interrupt)
if interrupt_pin:
print(interrupt_pin)
sleep(1)
