Please,How do I solve the network problem?
ws28422863
Post by ws28422863 » Sat Feb 08, 2020 1:45 pm
You cannot interrupt and enter instructions in putty, it will continuously repeat the content on the picture
This is my wifi connection
def connectAP(ssid, pwd):
    if not wlan.isconnected():
        wlan.active(True)
        wlan.connect(ssid, pwd)
        while not wlan.isconnected():
            pass
    print('network config:', wlan.ifconfig())
thank you!
kevinkk525
Re: Please,How do I solve the network problem?
Post by kevinkk525 » Sat Feb 08, 2020 3:29 pm
Apparently it doesn't find your AP so it never connects?
Therefore it doesn't stop printing those messages, unless you issue wlan.active(False)
A small note, use this instead of a busy loop:
            time.sleep_ms(50)
Kevin Köck
ws28422863
Post by ws28422863 » Sun Feb 09, 2020 10:12 am
            time.sleep_ms(50)
Thanks for your reply
So if time.sleep_ms (50) is used, will it not be infinitely reincarnation?
Because I want to test without finding the AP
kevinkk525
Post by kevinkk525 » Sun Feb 09, 2020 11:07 am
No, time.sleep() doesn't change the behaviour. It is just the recommended way.
The messages in the repl are just debug messages, you can ignore them in your program. if you are writing to the repl, use wifi.active(False) to disable your wifi and they will go away.
There should be a command for disabling the esp-idf debug messages (something like esp.debug....) but I forgot the command, sorry.
Kevin Köck
kevinkk525
Post by kevinkk525 » Sun Feb 09, 2020 1:30 pm
jimmo wrote:
Sun Feb 09, 2020 1:28 pm
The log messages come from the ESP32 IDF.
I think some of these messages can't be turned off due to bugs with the way the IDF log level checking works, but there is some control of this using esp.osdebug
e.g.
import esp
esp.osdebug(esp.LOG_NONE)
I don't normally use esp32 other than when I was working on BLE support. I remember I found the logging fairly inconsistent. I'll double check when I check the write truncation tomorrow.
This might be it
Kevin Köck
Post by jimmo » Sun Feb 09, 2020 1:32 pm
It's esp.osdebug -- I just happened to mention to look that up for a different thread, see viewtopic.php?f=18&t=7719#p44072
(But like I said there, the IDF logging doesn't always check the value of this option...)
(Ah, sorry Kevin, looks like you just beat me to it :) )
