Please,How do I solve the network problem?
Posted: Sat Feb 08, 2020 1:45 pm
by ws28422863
You cannot interrupt and enter instructions in putty, it will continuously repeat the content on the picture
This is my wifi connection
def connectAP(ssid, pwd):
if not wlan.isconnected():
wlan.active(True)
wlan.connect(ssid, pwd)
while not wlan.isconnected():
pass
print('network config:', wlan.ifconfig())
thank you!
Re: Please,How do I solve the network problem?
Posted: Sat Feb 08, 2020 3:29 pm
by kevinkk525
Apparently it doesn't find your AP so it never connects?
Therefore it doesn't stop printing those messages, unless you issue wlan.active(False)
A small note, use this instead of a busy loop:
time.sleep_ms(50)
Posted: Sun Feb 09, 2020 10:12 am
by ws28422863
kevinkk525 wrote: ↑Sat Feb 08, 2020 3:29 pm
time.sleep_ms(50)
Thanks for your reply
So if time.sleep_ms (50) is used, will it not be infinitely reincarnation?
Because I want to test without finding the AP
Posted: Sun Feb 09, 2020 11:07 am
by kevinkk525
No, time.sleep() doesn't change the behaviour. It is just the recommended way.
The messages in the repl are just debug messages, you can ignore them in your program. if you are writing to the repl, use wifi.active(False) to disable your wifi and they will go away.
There should be a command for disabling the esp-idf debug messages (something like esp.debug....) but I forgot the command, sorry.
Posted: Sun Feb 09, 2020 1:30 pm
by kevinkk525
jimmo wrote: ↑Sun Feb 09, 2020 1:28 pm
The log messages come from the ESP32 IDF.
I think some of these messages can't be turned off due to bugs with the way the IDF log level checking works, but there is some control of this using esp.osdebug
e.g.
import esp
esp.osdebug(esp.LOG_NONE)
I don't normally use esp32 other than when I was working on BLE support. I remember I found the logging fairly inconsistent. I'll double check when I check the write truncation tomorrow.
This might be it
Posted: Sun Feb 09, 2020 1:32 pm
by jimmo
It's esp.osdebug -- I just happened to mention to look that up for a different thread, see
viewtopic.php?f=18&t=7719#p44072
(But like I said there, the IDF logging doesn't always check the value of this option...)
(Ah, sorry Kevin, looks like you just beat me to it
