SPI ESP32
striker
SPI ESP32
Post by striker » Sun Feb 16, 2020 12:20 pm
I'm trying to run simple display code on this esp32 board
board:https://github.com/Xinyuan-LilyGO/TTGO-T-Display
code: https://github.com/russhughes/st7789_mpy
it works if I run the script from uPyCraft but it's not working if I just power up the device.
I'm sure that the code is working - backlight is lighting up and I'd added some debug strings
I uploaded the code here https://drive.google.com/file/d/1a6u3Ns ... HjY_kKHr0p
Re: SPI ESP32
Post by jimmo » Sun Feb 16, 2020 11:45 pm
Is the code in main.py (or imported and run from main.py)?
Probably the best thing to try is to add some print() statements to the code, copy the files onto the filesystem, open up the REPL, then hit Ctrl-D and you should see the code running.
