Hi, im have problem in installing modules via upip:
>>> upip.install('micropython-uasyncio')
Installing to: /lib/
Error installing 'micropython-uasyncio': list index out of range, packages may be partially installed
upip - list index out of range.
Re: upip - list index out of range.
Sadly the error messages produced by upip are unhelpful. These errors may be provoked by a lack of network connectivity or an incorrect package name - although in your case the name is correct. Have you checked that your ESP32 is online?
I had a connection problem, it's ok. Thanks.
