Page 1 of 2
Display image on a html page from main.py
Posted: Fri Mar 06, 2020 9:50 am
by ChrisB
I am trying to display a logo on a html page.
The code is on main.py
<h1>PHLOX Web Server</h1>
<img src="logo.jpg" alt="logo Phlox">
<li><a href="#Res">RESEAU</a> ;</li>
<br>
I loaded the image with main.py and boot.py
I guess the image is not at the right place or I should add a path to find it but I don't know how?
Thanks for your help
Chris
Re: Display image on a html page from main.py
Posted: Fri Mar 06, 2020 10:18 am
by jimmo
hi,
Which web server are you using? You'll need to handle the request for /logo.jpg and return the contents of the file from the filesystem (i assume you're already doing this for the html file?)
Posted: Fri Mar 06, 2020 10:53 am
by ChrisB
Hi Jimmo,
I don't use a web server just html code see below :
html = """
<!DOCTYPE html>
<html>
<head>
<title>Phlox Web Server</title>
<meta name="viewport" content="width=device-width, initial-scale=1">
<link rel="icon" href="data:,">
<style>html{font-family: Helvetica; display:inline-block; margin: 0px auto; text-align: center;}
img{margin-bottom:40px;}
h1{color: #0F3376; padding: 2vh;margin-top:40px;margin-bottom:40px;}
h2{margin-top:40px;margin-bottom:40px;}
li{margin-top:40px;margin-bottom:40px;}
p{font-size: 1.5rem;}
.button{display: inline-block; background-color: #e7bd3b; border: none; border-radius: 4px; color: white; padding: 16px 40px; text-decoration: none; font-size: 30px; margin: 2px; cursor: pointer;}
.button2{background-color: #4286f4;}</style>
</head>
<body>
<br>
<li><a href="#Lum">GESTION DES ECLAIRAGES</a> ;</li>
<br>
<hr>
<h2 id="Res">RESEAU</h2>
<br>
<hr>
<h2 id="Lum">GESTION DES ECLAIRAGES</h2>
<br>
<p>ECLAIRAGES: <strong>""" + gpio_state + """</strong></p>
<br>
<p><a href="/?led=on"><button class="button">ON</button></a></p>
<p><a href="/?led=off"><button class="button button2">OFF</button></a></p>
</body>
</html>"""
return html
In html to display an image, you are supposed to use <img src="image"> if the image is the same folder than the code.
Here they are in the same place but not in a folder see below
iMac-4:~ Chris$ ampy ls
/boot.py
/logo.jpg
/main.py
Chris
Posted: Fri Mar 06, 2020 3:36 pm
by bitninja
ChrisB wrote: ↑Fri Mar 06, 2020 10:53 am
I don't use a web server...
That's not going to work... you need an http server.
Posted: Fri Mar 06, 2020 4:28 pm
by ChrisB
why?
I can display an html page but I cannot attached an image to it without a web server ?
Quite strange...
I tried to use a web server but they are too heavy, you need to freeze them within the module folder inside the esp32 port and flash the firmware.
I could not achieve to do it using my iMac ...
Since I only want to display 1 html page I thought it would be easier to do it without web server ...
Chris
Posted: Fri Mar 06, 2020 4:39 pm
by bitninja
All you seem to be doing is dumping your html to the standard output. That is not the same thing as serving a web page to a browser over the network.
Posted: Fri Mar 06, 2020 11:16 pm
by mcauser
You can base64 encode an image and embed it in the html. Saves multiple http requests.
Still need a http server to send the html to a browser.
Which web server did you try, which was considered too heavy?
We might be able to suggest some alternatives.
Posted: Mon Mar 09, 2020 5:56 am
by ChrisB
I tried MicroWebSrv2.
I could not load any pages with it, too heavy...
I was told to freeze it but I was never able to do it.
Chris
Posted: Wed Mar 11, 2020 7:02 am
by ChrisB
No "light" web server to suggest?
Chris
Posted: Mon Mar 16, 2020 5:06 am
by jimmo
microdot ---
https://github.com/miguelgrinberg/micro ... es/gpio.py
It has a nice demo in the examples folder that shows how to serve a file from the filesystem.
