DHT22 on main.py returns with ETIMEDOUT
pccminister
Post by pccminister » Thu Mar 12, 2020 1:20 am
I tried to run this code on main.py:
import dht
dh = dht.DHT22(machine.Pin(4))
  dh.measure()
  time.sleep(2)
  tem = dh.temperature()
  hum = dh.humidity()
  print(hum , tem)
and got this error:
OSError: [Errno 110] ETIMEDOUT
when i run main.py after that error it runs OK.
how can i make it run main.py automatically after boot?
palivoda
Re: DHT22 on main.py returns with ETIMEDOUT
Post by palivoda » Thu Mar 12, 2020 10:46 pm
You can put your read block in to try-except block, e.g:
  # read DHT22 here
except:
  print("Cant read DHT22")
pccminister
Post by pccminister » Thu Mar 12, 2020 11:31 pm
  # read DHT22 here
except:
so I did this and it worked:
import dht
        dh.measure()
        time.sleep(2)
        hum = dh.humidity()
        print(hum , tem)
except OSError:
        print("cant read")
            dh.measure()
            time.sleep(2)
            hum = dh.humidity()
            print(hum , tem)
but I think there should be a better way!
palivoda
Post by palivoda » Fri Mar 13, 2020 12:22 pm
Sure:
import machine, dht, time, sys
		dht.measure()
        	time.sleep(2)
		hum = dh.humidity()
		print('Temp:', hum, 'C\tHumidity', tem, '%')
		time.sleep(1)
	except OSError as e:
		print("Cant read:", e)
		sys.print_exception(e)
Can you show output of the code? I use DHT22 without errors on first run.
Maybe there is something else in boot.py or main.py that causes the error.
jonaslorander
Post by jonaslorander » Fri Mar 13, 2020 12:42 pm
I had this same issue with a ESP8266 a few years back.
You can see my solution here:
viewtopic.php?f=16&t=2668#p16457
pccminister
Post by pccminister » Fri Mar 13, 2020 9:57 pm
Sure:
		dht.measure()
        	time.sleep(2)
		hum = dh.humidity()
		time.sleep(1)
I ran your code and this is the result:
Cant read: [Errno 110] ETIMEDOUT
  File "main.py", line 5, in <module>
  File "dht.py", line 16, in measure
Temp: 18.2 C	Humidity 34.2 %
Temp: 17.1 C	Humidity 32.5 %
Temp: 17.2 C	Humidity 32.5 %
Temp: 16.9 C	Humidity 32.5 %
Temp: 16.8 C	Humidity 32.5 %
pccminister
Post by pccminister » Fri Mar 13, 2020 10:00 pm
but you know that there are some tiny fixes about your code that should be applied!
there is a new Q:
why your code ran OK and my code needed me to repeat my Loop?
Post by jimmo » Mon Mar 16, 2020 4:05 am
I think it's because their code looks like this:
    .. measure
  except:
    .. ignore error
whereas yours looks like:
    .. measure
except:
i.e. the try/except needs to be around _only_ the measure, not the whole loop.
palivoda
Post by palivoda » Tue Mar 17, 2020 1:46 pm
there is a new Q:
try-except does not solve your problem - error on first read, but allow to ignore any read error and continue code exection.
Check something like this - http://www.blog.pythonlibrary.org/2012/ ... -handling/
I could only guess why you have error on first read:
1) check you dont do anything with this pin in boot.py
2) try to add time.sleep(2) right before "while True" line.
3) change sensor
4) check wires and resistors - http://cactus.io/hookups/sensors/temper ... ity-sensor
5) use osciloscope or data logger to see whats going on the data wire
