I'm using a ESP32 to transmit serveral kB worth of sensor data via WiFi.
I store these in a textfile where one line represents a sample:
22.5,42.0,1002.2,8.3
22.5,42.3,1002.2,8.3
22.5,42.5,1002.2,128.3
I basically use a new file to copy the lines to, and destroy the "donor" file at the end:
def HandleMeasBuffer(newData):
print("start transfer")
foundFiles = os.listdir()
if "log_A.txt" in foundFiles:
log_A = True
file1 = open("log_A.txt", 'r')
file2 = open("log_B.txt", 'w+')
log_A = False
file1 = open("log_B.txt", 'r')
file2 = open("log_A.txt", 'w+')
for num, f1 in enumerate(file1):
if num > 0: #forget first, oldest line
file2.write(f1)
file2.write("\n"+newData)
file1.close()
file2.close()
if log_A:
os.remove("log_A.txt")
os.remove("log_B.txt")
print("end transfer")
Sorry for the dumb question, I'm really not used to think much about system resources when it comes to regular Python
Thanks in advance for your help
