Page 1 of 2
ESP32 port + uasyncio + mqtt_as issue
Posted: Mon Apr 06, 2020 7:10 pm
by ChrisO
As far as I know, the esp32 port of micropython does not contain uasyncio
https://github.com/micropython/micropython is my source for micropython)
I have added and developed an application using
https://github.com/micropython/micropython-lib.
So far, I was under the impression that these sources are both part of "official build"
I'm starting to guess my assumptions are wrong because I am running into the following issue:
When trying to import and use Peter Hinch's mqtt_as.py an attempt to use uasyncio.Lock() is made... My version of uasyncio does not have Lock. I do have a lock as part of uasyncio/synchro.py but then of course the default import is different.
Is one of the correct ways of solving this to simply to do
inside my __init__.py considering I have a folder structure as such: ports/esp32/modules/uasyncio/[__init__.py,core.py,queues.py,synchro.py]
I mean... it works.... but I don't want to entangle myself into silly situations with weird, unique errors because nobody does it this way
(edit: typo's and grammar)
kind regards,
Chris
Re: ESP32 port + uasyncio + mqtt_as issue
Posted: Mon Apr 06, 2020 9:28 pm
by kevinkk525
The mqtt repo got updated to use the new uasyncio version that got merged into micropython recently. The daily builds of esp32 firmware has that new version. You should use that. The uasyncio modules from micropython-lib are not supported anymore.
Posted: Tue Apr 07, 2020 11:48 am
by ChrisO
Thank you for for your reply Kevin.
I was reading through the issues of the official build and it seems like Queues have not been implemented there yet.
https://github.com/micropython/micropython/issues/5828)
My implementation relies on this, so I don't think using the daily build is going to solve anything for now.
At least I know it is (being) integrated thanks to you.
I'll keep an eye on the daily builds!
regards,
Chris
Posted: Tue Apr 07, 2020 11:53 am
You might like to try this. I have tested it under new uasyncio. It isn't particularly efficient, but it does work. I should point out that it is based on the work of Paul Sokolovsky namely his implementation in uasyncio V2.
from ucollections import deque
import uasyncio as asyncio
# Exception raised by get_nowait().
class QueueEmpty(Exception):
pass
# Exception raised by put_nowait().
class QueueFull(Exception):
pass
class Queue:
def __init__(self, maxsize=0):
self.maxsize = maxsize
self._queue = deque((), maxsize)
def _get(self):
return self._queue.popleft()
async def get(self): # Usage: item = await queue.get()
while not self._queue:
# Queue is empty, put the calling Task on the waiting queue
await asyncio.sleep_ms(0)
return self._get()
def get_nowait(self): # Remove and return an item from the queue.
# Return an item if one is immediately available, else raise QueueEmpty.
if not self._queue:
raise QueueEmpty()
return self._get()
def _put(self, val):
self._queue.append(val)
async def put(self, val): # Usage: await queue.put(item)
while self.qsize() >= self.maxsize and self.maxsize:
# Queue full
# Task(s) waiting to get from queue, schedule first Task
self._put(val)
def put_nowait(self, val): # Put an item into the queue without blocking.
if self.qsize() >= self.maxsize and self.maxsize:
raise QueueFull()
self._put(val)
def qsize(self): # Number of items in the queue.
return len(self._queue)
def empty(self): # Return True if the queue is empty, False otherwise.
return not self._queue
def full(self): # Return True if there are maxsize items in the queue.
# Note: if the Queue was initialized with maxsize=0 (the default),
# then full() is never True.
if self.maxsize <= 0:
return False
return self.qsize() >= self.maxsize
[EDIT]
Removed error in the above pointed out by Kevin. Oddly it did work, but there was a definite mistake...
Posted: Tue Apr 07, 2020 1:38 pm
by ChrisO
Thank you Peter,
Using the official build + one or two extra's seems manageable.
(I forget a lot, so keeping things simple helps me)
I'm noticing that there's actually differences in micropython-lib classes and the official build.
This means I have to get back to the drawing board. (i.e. Event.set() no longer accepts an optional data argument)
Can topics be closed? I'll ask my follow-up question in a new thread
Posted: Tue Apr 07, 2020 5:02 pm
The official Event class is CPython compatible. The version in my asyn.py library had three differences from the current official one:
- It is an awaitable class.
- The .set() method can be called from an ISR.
- It has an optional data arg.
I have renamed this to Message while retaining this functionality. Note that the official Event is more efficient: mine relies on polling to achieve its ISR friendliness. If Event becomes ISR friendly I will make Message a subclass of Event to inherit its efficiency.
I've made these synchronisation primitives available
here. All work with V3 but many are stopgap solutions while we wait for official versions. There's no documentation yet, but their API is as per my existing docs. They are now implemented as a Python package so the import statements will change - see the test programs.
I'm working on a substantial revision of the micropython-async repo to provide for V3, but it may be a couple of weeks before it's ready.
Posted: Wed Apr 08, 2020 12:52 pm
by ChrisO
pythoncoder wrote: ↑Tue Apr 07, 2020 5:02 pm
...Note that the official Event is more efficient: mine relies on polling to achieve its ISR friendliness. If Event becomes ISR friendly I will make Message a subclass of Event to inherit its efficiency....
If I understand the code correctly, the Message class you have implemented only sets flags on itself.
The async wait method will loop until the flag becomes True. is this the polling you speak of?
# micropython-samples/uasyncio_iostream/v3/primitives/message.py
class Message():
def __init__(self, delay_ms=0):
self.delay_ms = delay_ms
self.clear()
def clear(self):
self._flag = False
self._data = None
async def wait(self): # CPython comptaibility
while not self._flag:
await asyncio.sleep_ms(self.delay_ms)
def __await__(self):
__iter__ = __await__
def is_set(self):
return self._flag
def set(self, data=None):
self._flag = True
self._data = data
def value(self):
return self._data
At first glance the official Event class does not look much different.
The only difference I can see, which is likely to be of great significance, is that the wait method is no loop at all.
It simple pushes the current task on a queue and returns true.
Later on, when an event is set, this pops the queue, returning a value or starting a new coroutine.
for completion, here's the Event class I was looking at:
# MicroPython uasyncio module
# MIT license; Copyright (c) 2019-2020 Damien P. George
from . import core
# Event class for primitive events that can be waited on, set, and cleared
class Event:
def __init__(self):
self.state = False # False=unset; True=set
self.waiting = core.TaskQueue() # Queue of Tasks waiting on completion of this event
def is_set(self):
return self.state
def set(self):
# Event becomes set, schedule any tasks waiting on it
while self.waiting.peek():
core._task_queue.push_head(self.waiting.pop_head())
self.state = True
def clear(self):
self.state = False
if not self.state:
# Event not set, put the calling task on the event's waiting queue
self.waiting.push_head(core.cur_task)
# Set calling task's data to the event's queue so it can be removed if needed
core.cur_task.data = self.waiting
yield
return True
Now, I know absolutely nothing about ISR's besides from what I read in 5 minutes looking at the docs... But you've peeked my interest.
What makes Event ISR unfriendly? As far as I can tell, the main loop gets interrupted only briefly and it will always wait for object creations to complete so no coro is left with any half updated object. What kind of use cases are ISR unfriendly?
regards,
Chris
Posted: Wed Apr 08, 2020 5:16 pm
Kevin produced proof that, if the interrupt occurs while the asyncio pairing heap is being updated, a failure occurs. Note that using micropython.schedule() will not fix that fundamental concurrency issue.
Posted: Sun Jun 28, 2020 8:37 pm
by uxhamby
Was there ever a resolution to this issue?
Thanks,
Brian H.
Posted: Sun Jun 28, 2020 9:12 pm
by kevinkk525
To Event not being ISR safe with uasyncio v3? There's currently a PR from Damien (
https://github.com/micropython/micropython/pull/6106) but nothing merged yet, might change too.
