Hello.
I have this bandwidth monitor that uses one of these neopixel rings to display network usage. It is updated 10x per second and it brings me joy to see the pixels blinking.
From time to time I see a random pixel on the array lighting up. I don't see any patterns.
I'm curious if this is an internal esp32-specific issue related to timing (I've issues with timing on other platforms) or if this is some caused by my local setup. Perhaps I have voltage drops that the cap on the neopixels isn't capable of mitigating.
Are neopixels on Micropython rock solid or are there glitches from time to time?
Cheers,
Per.
Spurious errors with Neopixels
Re: Spurious errors with Neopixels
This is a bit of a FAQ -- the neopixel implementation on ESP32 is not rock solid. There is work underway to improve it (using the hardware signal generator (called RMT on esp32)).
RMT support is already available in v1.12 and I believe someone has written a Python wrapper for neopixels (although I understand it had some limitations in terms of memory use per pixel) but hopefully someone else has more info.
Thanks!
That's all I needed to know. I'll see if I can dig up the RMT lib. I've used the RMT from C++ before and there are other working neopixel libs out there in other languages, so it should be doable to make this work.
This is the code Jimmo mentioned:
https://gist.github.com/nevercast/9c485 ... 4a22062795
Cheers
Seon
Cheers
Seon
