Is there some way to disable the built-in LED on my ESP32 board? It blinks with each polling instruction I think. So, if you have a button.value() call in a loop, it is constantly blinking. Annoying and a waste of power.
Cheers.
Builtin LED
Re: Builtin LED
If the LED connect to USB to TTL cobvertor, you can't control it.
Re: Builtin LED
OK. Thanks. I found the board schematic and you're right, it's hardwired to the mains. I guess the only option is to remove it. Cest la vie.
