LVGL and SD Card won't share SPI bus
PM-TPI
Post by PM-TPI » Fri May 15, 2020 3:34 pm
I posted in LittlevGl fourm also...
https://forum.littlevgl.com/t/lvgl-and- ... i-bus/2268
In post see...
This problem was fixed in espressif/esp-idf@067f3d2, but that commit is not included yet in Micropython (at least not on the last release v1.12, which lv_micropython is aligned to)
Is there a micropython fix planned??
Or a workaround??
Re: LVGL and SD Card won't share SPI bus
Post by pythoncoder » Fri May 15, 2020 5:37 pm
See this PR.
I hit this problem with a board where an SD card shares the bus with a chip. For reasons which nobody has yet explained successfully, it is necessary to send 0xff with the SD card CS False prior to accessing the card. You might like to try this version of sdcard.py.
Please post the outcome.
PM-TPI
Post by PM-TPI » Fri May 15, 2020 6:30 pm
This is my past initialization that would mount...
uos.mount(SDCard(slot=2, sck=18, miso=19, mosi=23, cs=4), '/sd')
tried...
    # uos.mount(SDCard(slot=2, sck=18, miso=19, mosi=23, cs=4), '/sd')
    sd = sdcard.SDCard(machine.SPI(1), machine.Pin(4))
    uos.mount(sd, '/sd')
    print(uos.listdir('/sd/data'))
except:
    print('\nSD Card Error\n')
get> SD Card Error
PM-TPI
Post by PM-TPI » Fri May 15, 2020 6:59 pm
got to mount...
spi = SPI(2, sck=Pin(18), mosi=Pin(23), miso=Pin(19) )
    sd = sdcard.SDCard(spi, Pin(4))
except:
but when lvgl initialized... not able to write to sd card
PM-TPI
Post by PM-TPI » Fri May 15, 2020 8:43 pm
If I initialized LVGL first...
and then mount sd card...
    sd = sdcard.SDCard(machine.SPI(1, sck=machine.Pin(18), mosi=machine.Pin(23), miso=machine.Pin(19)), machine.Pin(4))
except:
ILI9341 initialization completed
Enable backlight
Double buffer
E (4840) spi: SPI2 already claimed by spi master.
E (4840) spi_master: spi_bus_initialize(231): host already in use
SD Card Error
I am at a loss
Mike Teachman
Post by Mike Teachman » Sat May 16, 2020 12:20 am
Are you using the Python or C based ILI9341 display driver? If you use the C driver I found a work around ...
I faced the same problem and found a workaround by modifying the C based ILI9341 display driver, as follows:
- change the SPI bus config to full duplex
here are the code changes
custom lvgl branch: https://github.com/miketeachman/lv_bind ... treetsense
commit: https://github.com/miketeachman/lv_bind ... fbbf169885
specific file change: https://github.com/miketeachman/lv_bind ... 3712caR171
This problem is discussed a bit in this project log:
https://hackaday.io/project/162059-stre ... -littlevgl
The downside to this work around are slower display updates compared to half duplex operation.
Another useful display customization involved adding an option to the C based ILI9341 MicroPython interface where the display driver does not initialize the SPI bus - initialization is handled earlier in the program when the SD Card is initialized.
commit: https://github.com/miketeachman/lv_bind ... 84bf3ef9cd
A working example is shown in the StreetSense project:
https://github.com/miketeachman/micropy ... etsense.py
SD card init: https://github.com/miketeachman/micropy ... e.py#L1091
ILI9341 init: https://github.com/miketeachman/micropy ... se.py#L429
Hopefully this might help ! At least you know it can work.
Post by pythoncoder » Sat May 16, 2020 8:44 am
@PM-TPI Do I take it that this version of sdcard.py https://github.com/peterhinch/micropyth ... /sdcard.py didn't fix the problem?
PM-TPI
Post by PM-TPI » Sat May 16, 2020 11:57 am
Peter... yes using sdcard.py, your theory of the issues are exactly what I'm feeling is going on here.
Mike... I'm using the micropython version.
What is the philosophy of the changes in your C code that I can possibly apply to the uPy code?
Was your approach similar to Peters?
In trying to fix this issue I was Googling mostly "micropython ... yada yada" and got few results.
but when I Googled... "SD card shared SPI" then I got an avalanche of issues, but few with concise answers.
It is reported that using different SD cards have various successes.
Some mention using 100 Ohms termination resistors even on short lead runs <5".
I believe most failures are due to SD Cards that do not release the SPI bus back to the cpu.
When I saw your explanation Peter I thought your method was going to work.
it's possible I could still be implementing it incorrectly.
fstengel
Post by fstengel » Sat May 16, 2020 11:59 am
I just tried @pythoncoder's SDCard class. What happens is that:
  • claiming the bus using SPI(1) fails because the HSPI bus is already in use (by the screen). I expected that
  • claiming the bus using SPI(2) or SPI(2, sck=Pin(18), mosi=Pin(23), miso=Pin(19)) freezes the screen. furthermore one gets a "OSError: couldn't determine SD card version" exception...
I have used @Mike Teachman's solution (and the derived code I found in that repo https://github.com/sci-bots/lv_binding_ ... fed5fac8a2). It works. What bugs me is that I often got hard resets when I wanted a soft reset. I did not try too hard to find if the cause was the C driver or double buffering. For the time being I can wait some time until I have real need for an SD card.
PM-TPI
Post by PM-TPI » Sat May 16, 2020 7:41 pm
What did I get wrong....
got test(ili9341.py-shared-SPI)... changed ili9341.py settings for LOLIN D2 Pro
def __init__(self,
        miso=19, mosi=23, clk=18, cs=14, dc=27, rst=33, power=-1, backlight=32, backlight_on=1, power_on=1,
        spihost=esp.HSPI_HOST, mhz=40, factor=4, hybrid=True, width=320, height=240,
        colormode=COLOR_MODE_BGR, rot=LANDSCAPE, invert=False, double_buffer=True
mount SD Card
uos.mount(SDCard(slot=2, cs=4), '/sd')
it mounts and saves a file... good
then initialized LVGL and got...
>>> import tft
E (61690) spi_master: spi_bus_add_device(373): host not initialized
  File "tft.py", line 16, in <module>
  File "ili9341.py", line 121, in __init__
  File "ili9341.py", line 338, in init
  File "ili9341.py", line 218, in disp_spi_init
RuntimeError: Failed adding SPI device
