GPS - Coordinates - precision problem.
prem111
Post by prem111 » Wed May 20, 2020 9:09 pm
Reads coordinates from gps. The problem is the conversion from dms to dd. I achieve precision (lat, lon) type 12.12345 and I would like me to 12.123456. Working on esp32, is it possible?
Re: GPS - Coordinates - precision problem.
Post by pythoncoder » Thu May 21, 2020 6:26 am
On my reckoning the least significant digit you're seeing corresponds to about 1 meter. Do commercial GPS modules actually provide this level of absolute accuracy?
Assuming they do, there are two possible approaches. I believe it's possible to compile firmware to use double precision floats, so it would happen automatically.
Another option is to use an integer conversion, relying on the fact that Python supports arbitrary precision integers. Compute an integer value of (seconds * a_large_factor). This could be formatted as a float for printing or display.
prem111
Post by prem111 » Thu May 21, 2020 6:51 am
Thanks for reply.
What are the possibilities ? how can you do that ?
Thanks !!!
