PZEM04t V3 simple example whitout modbus library
Online
jnogues
Post by jnogues » Fri May 22, 2020 5:46 am
Hi! This is my first post.
Here is my example for use PZEM04t V3 energy monitor without modbus library,
using the default address 0xF8.
Next stop with mqtt.
Regards.
Micropython in esp32 simple example for use PZEM04t V3 in default modbus address 0xF8
whitout modbus library. Use UART1 or UART2.
2020-05-22
Jaume Nogues, jnogues@gmail.com
import time, struct
uart = UART(2, 9600, tx=13, rx=14) #UART2, tx=gpio13 rx=gpio14
count=0
def read_measures():
    signed=True
    uart.write(b'\xF8\x04\x00\x00\x00\x0A\x64\x64')#read all raw measures
    time.sleep(0.1)
    payload = uart.read()
    payload = payload[3:-2]
    response_quantity = int(len(payload) / 2)
    fmt = '>' + (('h' if signed else 'H') * response_quantity)
    return struct.unpack(fmt, payload)
def reset_energy():
    uart.write(b'\xF8\x42\xC2\x41')#reset energy
        #read all measures in one time
        all_measures = read_measures()
        print(all_measures)
        #split and print measues
        voltage = all_measures[0]/10.0
        print('U = ' + str(voltage) + ' V')
        current = ((all_measures[2]<<16) |  (all_measures[1]))/1000.0
        print('I = ' + str(current) + ' A')
        power = ((all_measures[4]<<16) |  (all_measures[3]))/10.0
        print('P = ' + str(power) + 'W')
        energy = ((all_measures[6]<<16) |  (all_measures[5]))/1000.0
        print('E = ' + str(energy) + 'kWh')
        freq = all_measures[7]/10.0
        print('freq = ' + str(freq) + ' Hz')
        pf = all_measures[8]/10.0
        print('power factor = ' + str(pf))
    except:
        #something wrong
        print('pzem04 reading error')
    #delay some seconds
    time.sleep(5)
