DS18B20 wrong serial code/adress/roms
BigStupidBeast
Post by BigStupidBeast » Thu May 28, 2020 5:49 pm
Hi.
I have ESP23 dev kit with micropython firmware XX.
I also have ds18b20 waterproof sensor (datasheet link: https://datasheets.maximintegrated.com/ ... S18B20.pdf
I wrote this code for it:
import time, onewire, ds18x20, machine
ds_pin=Pin(19)
ds_sensor = ds18x20.DS18X20(onewire.OneWire(ds_pin))
roms = ds_sensor.scan()
    print(rom)
It returns this info:
bytearray(b'(\xbcN6\x14\x19\x01\xba')
Before reading temp data from sensor, we first need to use the scan() function to scan for DS18B20 sensors. The addresses found are saved on the roms variable (the roms variable is of type list). scan() function sends request and sensor returns its unique 64-bit serial code.
I used manual here https://randomnerdtutorials.com/micropy ... 2-esp8266/
Today I bought two more ds18x20 waterproof sensors (I don’t know what type of sensor - ds18a20/ds18b20 or else - are they, ‘cause eager chinese manufacturers sealed sensors inside metal bullet too good, so I can’t just look inside).
I tried to run the same code with them, but it returned the following:
bytearray(b'(\xff\xff\xff\xff\xff\xff\xff')
bytearray(b'(\xfe\xff\xff\xff\xff\xff\xff')
bytearray(b'(\xfc\xff\xff\xff\xff\xff\xff')
bytearray(b'(\xf8\xff\xff\xff\xff\xff\xff')
bytearray(b'(\xf0\xff\xff\xff\xff\xff\xff')
bytearray(b'(\xd0\xff\xff\xff\xff\xff\xff')
bytearray(b'(\x90\xff\xff\xff\xff\xff\xff')
bytearray(b'(\x90\xfe\xff\xff\xff\xff\xff')
bytearray(b'(\x90\xf6\xff\xff\xff\xff\xff')
bytearray(b'(\x90\xe6\xff\xff\xff\xff\xff')
bytearray(b'(\x90\xc6\xff\xff\xff\xff\xff')
bytearray(b'(\x90\x86\xff\xff\xff\xff\xff')
bytearray(b'(\x90\x86\xfd\xff\xff\xff\xff')
bytearray(b'(\x90\x86\xf9\xff\xff\xff\xff')
bytearray(b'(\x90\x86y\xff\xff\xff\xff')
bytearray(b'(\x90\x86y\xfe\xff\xff\xff')
bytearray(b'(\x90\x86y\xfa\xff\xff\xff')
bytearray(b'(\x90\x86y\xf2\xff\xff\xff')
bytearray(b'(\x90\x86y\xe2\xff\xff\xff')
bytearray(b'(\x90\x86y\xa2\xff\xff\xff')
bytearray(b'(\x90\x86y\xa2\xfd\xff\xff')
bytearray(b'(\x90\x86y\xa2\xf9\xff\xff')
bytearray(b'(\x90\x86y\xa2\xf1\xff\xff')
bytearray(b'(\x90\x86y\xa2\xe1\xff\xff')
bytearray(b'(\x90\x86y\xa2\xc1\xff\xff')
bytearray(b'(\x90\x86y\xa2\x81\xff\xff')
bytearray(b'(\x90\x86y\xa2\x01\xff\xff')
bytearray(b'(\x90\x86y\xa2\x01\xfb\xff')
bytearray(b'(\x90\x86y\xa2\x01\xf3\xff')
bytearray(b'(\x90\x86y\xa2\x01\xe3\xff')
bytearray(b'(\x90\x86y\xa2\x01\xc3\xff')
bytearray(b'(\x90\x86y\xa2\x01\x83\xff')
bytearray(b'(\x90\x86y\xa2\x01\x03\xff')
bytearray(b'(\x90\x86y\xa2\x01\x03\xfe')
bytearray(b'(\x90\x86y\xa2\x01\x03\xfc')
bytearray(b'(\x90\x86y\xa2\x01\x03\xdc')
bytearray(b'(\x90\x86y\xa2\x01\x03\\')
When I try to read temperature using this values it returns ‘CRC error’.
What can be done? Is the problem with code, or the sensors are failed somehow?
Re: DS18B20 wrong serial code/adress/roms
Post by Roberthh » Thu May 28, 2020 6:04 pm
It may be a fake sensor. See also https://github.com/cpetrich/counterfeit_DS18B20
kevinkk525
Post by kevinkk525 » Thu May 28, 2020 6:17 pm
Kevin Köck
BigStupidBeast
Post by BigStupidBeast » Sat May 30, 2020 8:46 am
viewtopic.php?f=2&t=8180&p=46521&hilit=ds18b20#p46528 maybe too many units on one bus?
one sensor wired in normal mode (not parasite). positive power connected to 3.3V. the first sensor work with out pull up resistor. But China so diffrent China... I try to use inner pull up mode (Pin.PULL_UP) but it didn't help.
My first thought it was.
Thanks. will go to store for new sensors
SirN Check
Post by SirN Check » Fri Jun 05, 2020 11:45 pm
Don't forget to also pick up some pull-up resistors!
Internal pull-up are much too weak.
At 3v3: 1k5, 1k8 or 2k2 will do the trick.
Especially when using long cables & multiple sensors!
BigStupidBeast
Post by BigStupidBeast » Sun Jun 07, 2020 3:06 pm
Looks like i'm a fool)) Yes. One 4.7K pull up resistor and it's alive! IT'S ALIVE!! Aaaand whats'up doc? then we use internal PULL_UP mode we pull up signal only for ESP. BUT! DS18B20 is microchip too. And the wire for little DS18B20 is like giant radio aerial. Maybe in my first sensor this problem was solved on hard level.
