Pre-bake vfs partition
urielka
Post by urielka » Fri May 29, 2020 12:17 pm
I am working in a factory setting where I want to keep in each device a secret token unique to each device as part of flashing the device with my custom micropython build.
My idea for doing this is:
1. Build a fat32 partition using the following commands on the host:
dd if=/dev/zero of=fat.fs bs=1024 count=2048
mkfs.vfat fat.fs
2. Mount the partition and add my files (code and secret token)
3. Perform regular flash of micropython via esptool.py with an extra write_flash to the offset (0x200000) defined in the partitions.csv with the image
As far as I understand the code in inisetup which is called by _boot.py will create a vfat partition if it fails to mount the vfs partition on first boot.
Will this work? is there an easier solution?
urielka
Re: Pre-bake vfs partition
Post by urielka » Fri May 29, 2020 2:44 pm
For anyone who might care:
Seems to work :)
Use https://pypi.org/project/littlefs-python/ for editing the filesystem, I missed the fact it is using littlefs and not vfat
