ESP32 firmwares with single/double precision and ulab module
- rcolistete
I've compiled ESP32 firmwares with many combinations of single/double precision (float point numbers), ESP-IDF v3.3/4.0 and ulab module, look at :
Firmwares for MicroPython on ESP32.
- MicroPython v1.12 firmwares without ulab :
* 16 firmwares with combinations of sp, dp, ESP-IDF v3.3, ESP-IDF v4.0 for 4 types of ESP32 boards;
- MicroPython v1.12 firmwares with ulab :
* 16 firmwares with ulab v0.54.0 and combinations of sp, dp, ESP-IDF v3.3, ESP-IDF v4.0 for 4 types of ESP32 boards.
Changed in 2020-08-07 : pointing to https://gitlab.com/rcolistete/micropython-firmwares
Re: ESP32 firmwares with single/double precision and ulab module
I think this is really useful, but I would like to suggest a change to the structure of your repository: would it be possible to put all firmware files in the same main directory, so that I could simply link to it in https://github.com/v923z/micropython-ul ... d#firmware, without having to spell out for which boards you have compiled the code.rcolistete wrote: ↑Mon Aug 03, 2020 6:34 amI've compiled ESP32 firmwares with many combinations of single/double precision (float point numbers), ESP-IDF v3.3/4.0 and ulab module, look at :
* 16 firmwares with ulab and combinations of sp, dp, ESP-IDF v3.3, ESP-IDF v4.0 for 4 types of ESP32 boards.
As it is now, I can't just say, "go to https://gitlab.com/rcolistete/micropyth ... ee/master/", because that contains a lot of other files, but they are not consistent: the M5stack has no firmware files, while the https://gitlab.com/rcolistete/micropyth ... ster/Pycom has scripts etc.
I think, it would be significantly better, if you had a separate repository for firmware, and in that you could have folders for the various boards, and within those for various versions etc. But at the moment, there is really not too much separation between firmware, scripts, and perhaps other things.
- rcolistete
I was also thinking to separate into more repositories...
Different repository only for MicroPyton firmwares with ulab ? Or the repository can have non-ulad and ulab firmwares ?
I just meant that the firmware files should have a distinct repository. I don't care, if you mix different types of firmware there.rcolistete wrote: ↑Mon Aug 03, 2020 5:53 pmI was also thinking to separate into more repositories...
- rcolistete
Done, all of my MicroPython built firmwares in one dedicated repository :
https://gitlab.com/rcolistete/micropython-firmwares/
OK, thanks! I will update the link on my side.rcolistete wrote: ↑Fri Aug 07, 2020 9:37 amDone, all of my MicroPython built firmwares in one dedicated repository :
Hi
I urgently need a help please.
I have ESP32 WROOM 32. Installed micropython-1.18.zip (113MiB). Installed Thonny , UPyCraft,
But When try to install ulab in Thonny, it doesn't find. Yesterday I saw this topic and tried to install firmware with ulab. https://gitlab.com/rcolistete/micropyth ... _flash-4MB.
But didn't work. The compiler said stop the program.
Please help. What should I do to install ulab.
Thank you very much for your answers
This is a very old piece of firmware, I really wouldn't use it, if I were you.Husyn wrote: ↑Sun Jan 23, 2022 9:15 amI have ESP32 WROOM 32. Installed micropython-1.18.zip (113MiB). Installed Thonny , UPyCraft,
I don't quite understand, how you want to install ulab. ulab is an inseparable part of the micropython firmware, a C module, which has to be compiled. The firmware you linked to has ulab + micropython v.1.12. You cannot add a newer version of ulab to it.
What you can do is get the code and compile it as described here https://github.com/v923z/micropython-ul ... sed-boards, and then upload the resulting firmware.
On a related note, some people, myself included, have been thinking about setting up a website that would have the infrastructure to nightly compile the latest code from micropython, and ulab, so that people could simply download the firmware without any hassle. Could anyone comment on what it would involve, e.g., how many boards are supported at the moment, do we have to think about customisation options etc. Any insight would be appreciated.
Thank you for answers
Unfortunately.
Cant install.
And cant see that anyone install it for esp32. No videos no document.
I m depressed
Unfortunately.
Cant install.
I m depressed
The documentation that I linked to is quite detailed. When you say you can't install it, what do you refer to? The toolchain, or the firmware, or something else? It is a bit hard to help, if the circumstances are not known...
Many people use micropython (and ulab) with the ESP32. However, if you don't insist on using micropython, you can download circuitpython's nightly build. Here is a list of their supported boards: https://circuitpython.org/downloads. Find yours, and download the firmware.
