I am trying to port a driver for the RFM69x modules that is currently written in Circuitpython and I am very close. All of the TX functionality is working as it should but I am having issues receiving packets correctly. The radio module uses SPI and I have traced down the where there is an issue. The function below takes in a register address to write to and a buffer to readinto. The length of the buffer is determined from another SPI transaction that provides the length of the packet in bytes (that part works fine). The circuit python code works on supported devices. When a register value of 0x00 is written the packet data is read into the buffer. When I try to do this in MP, I get some of the packet data but I am missing some bytes. I have messed with the buffer length and tried everything I can think of. If I write a register value using MP and read just one byte I get the expected value fine, example temperature, or chip version, etc. The full Circuitpython code is linked below and I pasted the full MP code I am working off of. I have tried a few ESP32 devices and an ESP8266 and I get the same result. Basically I get all of the bytes that were transmitted to the radio but its missing the first 4 header bytes which are needed. Just seeing if anyone noticed anything glaring or has any suggestions. So close to having this working. Thanks
def _read_into(self, address, buf, length=None):
# Read a number of bytes from the specified address into the provided
# buffer. If length is not specified (the default) the entire buffer
# will be filled.
if length is None:
length = len(buf)
with self._device as device:
self._BUFFER[0] = address & 0x7F # Strip out top bit to set 0
# value (read).
device.write(self._BUFFER, end=1)
device.readinto(buf, end=length)
# will be filled.
if length is None:
length = len(buf)
# value (read).
self.cs.value(0)
self.spi.write(bytes([address & 0x7F]))
self.spi.readinto(buf)
self.cs.value(1)
return buf
https://github.com/adafruit/Adafruit_Ci ... t_rfm69.py
Full MP code
import random
from micropython import const
# Internal constants:
_REG_FIFO = const(0x00)
_REG_OP_MODE = const(0x01)
_REG_DATA_MOD = const(0x02)
_REG_BITRATE_MSB = const(0x03)
_REG_BITRATE_LSB = const(0x04)
_REG_FDEV_MSB = const(0x05)
_REG_FDEV_LSB = const(0x06)
_REG_FRF_MSB = const(0x07)
_REG_FRF_MID = const(0x08)
_REG_FRF_LSB = const(0x09)
_REG_VERSION = const(0x10)
_REG_PA_LEVEL = const(0x11)
_REG_RX_BW = const(0x19)
_REG_AFC_BW = const(0x1A)
_REG_RSSI_VALUE = const(0x24)
_REG_DIO_MAPPING1 = const(0x25)
_REG_IRQ_FLAGS1 = const(0x27)
_REG_IRQ_FLAGS2 = const(0x28)
_REG_PREAMBLE_MSB = const(0x2C)
_REG_PREAMBLE_LSB = const(0x2D)
_REG_SYNC_CONFIG = const(0x2E)
_REG_SYNC_VALUE1 = const(0x2F)
_REG_PACKET_CONFIG1 = const(0x37)
_REG_FIFO_THRESH = const(0x3C)
_REG_PACKET_CONFIG2 = const(0x3D)
_REG_AES_KEY1 = const(0x3E)
_REG_TEMP1 = const(0x4E)
_REG_TEMP2 = const(0x4F)
_REG_TEST_PA1 = const(0x5A)
_REG_TEST_PA2 = const(0x5C)
_REG_TEST_DAGC = const(0x6F)
_TEST_PA1_NORMAL = const(0x55)
_TEST_PA1_BOOST = const(0x5D)
_TEST_PA2_NORMAL = const(0x70)
_TEST_PA2_BOOST = const(0x7C)
# The crystal oscillator frequency and frequency synthesizer step size.
# See the datasheet for details of this calculation.
_FXOSC = 32000000.0
_FSTEP = _FXOSC / 524288
# RadioHead specific compatibility constants.
_RH_BROADCAST_ADDRESS = const(0xFF)
# The acknowledgement bit in the FLAGS
# The top 4 bits of the flags are reserved for RadioHead. The lower 4 bits are reserved
# for application layer use.
_RH_FLAGS_ACK = const(0x80)
_RH_FLAGS_RETRY = const(0x40)
# User facing constants:
SLEEP_MODE = 0b000
STANDBY_MODE = 0b001
FS_MODE = 0b010
TX_MODE = 0b011
RX_MODE = 0b100
class RFM69:
# Global buffer for SPI commands.
_BUFFER = bytearray(4)
class _RegisterBits:
def __init__(self, address, *, offset=0, bits=1):
assert 0 <= offset <= 7
assert 1 <= bits <= 8
assert (offset + bits) <= 8
self._address = address
self._mask = 0
for _ in range(bits):
self._mask <<= 1
self._mask |= 1
self._mask <<= offset
self._offset = offset
def __get__(self, obj, objtype):
reg_value = obj._read_u8(self._address)
return (reg_value & self._mask) >> self._offset
def __set__(self, obj, val):
reg_value &= ~self._mask
reg_value |= (val & 0xFF) << self._offset
obj._write_u8(self._address, reg_value)
# Control bits from the registers of the chip:
data_mode = _RegisterBits(_REG_DATA_MOD, offset=5, bits=2)
modulation_type = _RegisterBits(_REG_DATA_MOD, offset=3, bits=2)
modulation_shaping = _RegisterBits(_REG_DATA_MOD, offset=0, bits=2)
temp_start = _RegisterBits(_REG_TEMP1, offset=3)
temp_running = _RegisterBits(_REG_TEMP1, offset=2)
sync_on = _RegisterBits(_REG_SYNC_CONFIG, offset=7)
sync_size = _RegisterBits(_REG_SYNC_CONFIG, offset=3, bits=3)
aes_on = _RegisterBits(_REG_PACKET_CONFIG2, offset=0)
pa_0_on = _RegisterBits(_REG_PA_LEVEL, offset=7)
pa_1_on = _RegisterBits(_REG_PA_LEVEL, offset=6)
pa_2_on = _RegisterBits(_REG_PA_LEVEL, offset=5)
output_power = _RegisterBits(_REG_PA_LEVEL, offset=0, bits=5)
rx_bw_dcc_freq = _RegisterBits(_REG_RX_BW, offset=5, bits=3)
rx_bw_mantissa = _RegisterBits(_REG_RX_BW, offset=3, bits=2)
rx_bw_exponent = _RegisterBits(_REG_RX_BW, offset=0, bits=3)
afc_bw_dcc_freq = _RegisterBits(_REG_AFC_BW, offset=5, bits=3)
afc_bw_mantissa = _RegisterBits(_REG_AFC_BW, offset=3, bits=2)
afc_bw_exponent = _RegisterBits(_REG_AFC_BW, offset=0, bits=3)
packet_format = _RegisterBits(_REG_PACKET_CONFIG1, offset=7, bits=1)
dc_free = _RegisterBits(_REG_PACKET_CONFIG1, offset=5, bits=2)
crc_on = _RegisterBits(_REG_PACKET_CONFIG1, offset=4, bits=1)
crc_auto_clear_off = _RegisterBits(_REG_PACKET_CONFIG1, offset=3, bits=1)
address_filter = _RegisterBits(_REG_PACKET_CONFIG1, offset=1, bits=2)
mode_ready = _RegisterBits(_REG_IRQ_FLAGS1, offset=7)
rx_ready = _RegisterBits(_REG_IRQ_FLAGS1, offset=6)
tx_ready = _RegisterBits(_REG_IRQ_FLAGS1, offset=5)
dio_0_mapping = _RegisterBits(_REG_DIO_MAPPING1, offset=6, bits=2)
packet_sent = _RegisterBits(_REG_IRQ_FLAGS2, offset=3)
payload_ready = _RegisterBits(_REG_IRQ_FLAGS2, offset=2)
def __init__(
self,
spi,
cs,
reset,
frequency,
sync_word=b"\x2D\xD4",
preamble_length=4,
encryption_key=None,
high_power=True,
self._tx_power = 13
self.high_power = high_power
self.spi = spi
self.cs = cs
self._reset = reset
self.reset() # Reset the chip.
# Check the version of the chip.
version = self._read_u8(_REG_VERSION)
if version != 0x24:
raise RuntimeError(
"Failed to find RFM69 with expected version, check wiring!"
self.idle() # Enter idle state.
# Setup the chip in a similar way to the RadioHead RFM69 library.
# Set FIFO TX condition to not empty and the default FIFO threshold to 15.
self._write_u8(_REG_FIFO_THRESH, 0b10001111)
# Configure low beta off.
self._write_u8(_REG_TEST_DAGC, 0x30)
# Disable boost.
self._write_u8(_REG_TEST_PA1, _TEST_PA1_NORMAL)
self._write_u8(_REG_TEST_PA2, _TEST_PA2_NORMAL)
# Set the syncronization word.
self.sync_word = sync_word
self.preamble_length = preamble_length # Set the preamble length.
self.frequency_mhz = frequency # Set frequency.
self.encryption_key = encryption_key # Set encryption key.
# set radio configuration parameters
self._configure_radio()
# initialize last RSSI reading
self.last_rssi = 0.0
"""The RSSI of the last received packet. Stored when the packet was received.
This instantaneous RSSI value may not be accurate once the
operating mode has been changed.
# initialize timeouts and delays delays
self.ack_wait = 0.5
"""The delay time before attempting a retry after not receiving an ACK"""
self.receive_timeout = 0.5
"""The amount of time to poll for a received packet.
If no packet is received, the returned packet will be None
self.xmit_timeout = 2.0
"""The amount of time to wait for the HW to transmit the packet.
This is mainly used to prevent a hang due to a HW issue
self.ack_retries = 5
"""The number of ACK retries before reporting a failure."""
self.ack_delay = None
"""The delay time before attemting to send an ACK.
If ACKs are being missed try setting this to .1 or .2.
# initialize sequence number counter for reliabe datagram mode
self.sequence_number = 0
# create seen Ids list
self.seen_ids = bytearray(256)
# initialize packet header
# node address - default is broadcast
self.node = _RH_BROADCAST_ADDRESS
"""The default address of this Node. (0-255).
If not 255 (0xff) then only packets address to this node will be accepted.
First byte of the RadioHead header.
# destination address - default is broadcast
self.destination = _RH_BROADCAST_ADDRESS
"""The default destination address for packet transmissions. (0-255).
If 255 (0xff) then any receiving node should accept the packet.
Second byte of the RadioHead header.
# ID - contains seq count for reliable datagram mode
self.identifier = 0
"""Automatically set to the sequence number when send_with_ack() used.
Third byte of the RadioHead header.
# flags - identifies ack/reetry packet for reliable datagram mode
self.flags = 0
"""Upper 4 bits reserved for use by Reliable Datagram Mode.
Lower 4 bits may be used to pass information.
Fourth byte of the RadioHead header.
def _configure_radio(self):
# Configure modulation for RadioHead library GFSK_Rb250Fd250 mode
# by default. Users with advanced knowledge can manually reconfigure
# for any other mode (consulting the datasheet is absolutely
# necessary!).
self.data_mode = 0b00 # Packet mode
self.modulation_type = 0b00 # FSK modulation
self.modulation_shaping = 0b01 # Gaussian filter, BT=1.0
self.bitrate = 250000 # 250kbs
self.frequency_deviation = 250000 # 250khz
self.rx_bw_dcc_freq = 0b111 # RxBw register = 0xE0
self.rx_bw_mantissa = 0b00
self.rx_bw_exponent = 0b000
self.afc_bw_dcc_freq = 0b111 # AfcBw register = 0xE0
self.afc_bw_mantissa = 0b00
self.afc_bw_exponent = 0b000
self.packet_format = 1 # Variable length.
self.dc_free = 0b10 # Whitening
self.crc_on = 1 # CRC enabled
self.crc_auto_clear = 0 # Clear FIFO on CRC fail
self.address_filtering = 0b00 # No address filtering
# Set transmit power to 13 dBm, a safe value any module supports.
self.tx_power = 13
# pylint: disable=no-member
# Reconsider this disable when it can be tested.
# read_into(_REG_FIFO, packet)
# will be filled.
if length is None:
length = len(buf)
# value (read).
self.cs.value(0)
#self.spi.write(self._BUFFER)
self.cs.value(1)
return buf
def _read_u8(self, address):
# Read a single byte from the provided address and return it.
self._read_into(address, self._BUFFER, length=1)
return self._BUFFER[0]
def _write_from(self, address, buf, length=None):
# Write a number of bytes to the provided address and taken from the
# provided buffer. If no length is specified (the default) the entire
# buffer is written.
if length is None:
length = len(buf)
# self._BUFFER[0] = (address | 0x80) & 0xFF # Set top bit to 1 to
# indicate a write.
self.cs.value(0)
self.spi.write(bytes([(address | 0x80) & 0xFF]))
self.spi.write(buf) # send data
self.cs.value(1)
def _write_fifo_from(self, buf, length=None):
# Write a number of bytes to the transmit FIFO and taken from the
if length is None:
length = len(buf)
buf1 = (_REG_FIFO | 0x80) & 0xFF # Set top bit to 1 to
# indicate a write.
buf2 = length & 0xFF # Set packt length
self.cs.value(0)
self.spi.write(bytes([buf1,buf2])) # send address and lenght)
self.cs.value(1)
def _write_u8(self, address, val):
# Write a byte register to the chip. Specify the 7-bit address and the
# 8-bit value to write to that address.
address = (address | 0x80) & 0xFF # Set top bit to 1 to
# indicate a write.
val = val & 0xFF
self.cs.value(0)
self.spi.write(bytes([address,val]))
self.cs.value(1)
def reset(self):
"""Perform a reset of the chip."""
# See section 7.2.2 of the datasheet for reset description.
self._reset.value(1)
time.sleep(0.0001) # 100 us
self._reset.value(0)
time.sleep(0.005) # 5 ms
def idle(self):
"""Enter idle standby mode (switching off high power amplifiers if necessary)."""
# Like RadioHead library, turn off high power boost if enabled.
if self._tx_power >= 18:
self.operation_mode = STANDBY_MODE
def sleep(self):
"""Enter sleep mode."""
self.operation_mode = SLEEP_MODE
def listen(self):
"""Listen for packets to be received by the chip. Use :py:func:`receive` to listen, wait
and retrieve packets as they're available.
# Enable payload ready interrupt for D0 line.
self.dio_0_mapping = 0b01
# Enter RX mode (will clear FIFO!).
self.operation_mode = RX_MODE
def transmit(self):
"""Transmit a packet which is queued in the FIFO. This is a low level function for
entering transmit mode and more. For generating and transmitting a packet of data use
:py:func:`send` instead.
# Like RadioHead library, turn on high power boost if enabled.
self._write_u8(_REG_TEST_PA1, _TEST_PA1_BOOST)
self._write_u8(_REG_TEST_PA2, _TEST_PA2_BOOST)
# Enable packet sent interrupt for D0 line.
self.dio_0_mapping = 0b00
# Enter TX mode (will clear FIFO!).
self.operation_mode = TX_MODE
@property
def temperature(self):
"""The internal temperature of the chip in degrees Celsius. Be warned this is not
calibrated or very accurate.
.. warning:: Reading this will STOP any receiving/sending that might be happening!
# Start a measurement then poll the measurement finished bit.
self.temp_start = 1
while self.temp_running > 0:
pass
# Grab the temperature value and convert it to Celsius.
# This uses the same observed value formula from the Radiohead library.
temp = self._read_u8(_REG_TEMP2)
return 166.0 - temp
@property
def operation_mode(self):
"""The operation mode value. Unless you're manually controlling the chip you shouldn't
change the operation_mode with this property as other side-effects are required for
changing logical modes--use :py:func:`idle`, :py:func:`sleep`, :py:func:`transmit`,
:py:func:`listen` instead to signal intent for explicit logical modes.
op_mode = self._read_u8(_REG_OP_MODE)
return (op_mode >> 2) & 0b111
@operation_mode.setter
def operation_mode(self, val):
assert 0 <= val <= 4
# Set the mode bits inside the operation mode register.
op_mode &= 0b11100011
op_mode |= val << 2
self._write_u8(_REG_OP_MODE, op_mode)
# Wait for mode to change by polling interrupt bit.
while not self.mode_ready:
pass
@property
def sync_word(self):
"""The synchronization word value. This is a byte string up to 8 bytes long (64 bits)
which indicates the synchronization word for transmitted and received packets. Any
received packet which does not include this sync word will be ignored. The default value
is 0x2D, 0xD4 which matches the RadioHead RFM69 library. Setting a value of None will
disable synchronization word matching entirely.
# Handle when sync word is disabled..
if not self.sync_on:
return None
# Sync word is not disabled so read the current value.
sync_word_length = self.sync_size + 1 # Sync word size is offset by 1
# according to datasheet.
sync_word = bytearray(sync_word_length)
self._read_into(_REG_SYNC_VALUE1, sync_word)
return sync_word
@sync_word.setter
def sync_word(self, val):
# Handle disabling sync word when None value is set.
if val is None:
self.sync_on = 0
# Check sync word is at most 8 bytes.
assert 1 <= len(val) <= 8
# Update the value, size and turn on the sync word.
self._write_from(_REG_SYNC_VALUE1, val)
self.sync_size = len(val) - 1 # Again sync word size is offset by
# 1 according to datasheet.
self.sync_on = 1
@property
def preamble_length(self):
"""The length of the preamble for sent and received packets, an unsigned 16-bit value.
Received packets must match this length or they are ignored! Set to 4 to match the
msb = self._read_u8(_REG_PREAMBLE_MSB)
lsb = self._read_u8(_REG_PREAMBLE_LSB)
return ((msb << 8) | lsb) & 0xFFFF
@preamble_length.setter
def preamble_length(self, val):
assert 0 <= val <= 65535
self._write_u8(_REG_PREAMBLE_MSB, (val >> 8) & 0xFF)
self._write_u8(_REG_PREAMBLE_LSB, val & 0xFF)
@property
def frequency_mhz(self):
"""The frequency of the radio in Megahertz. Only the allowed values for your radio must be
specified (i.e. 433 vs. 915 mhz)!
# FRF register is computed from the frequency following the datasheet.
# See section 6.2 and FRF register description.
# Read bytes of FRF register and assemble into a 24-bit unsigned value.
msb = self._read_u8(_REG_FRF_MSB)
mid = self._read_u8(_REG_FRF_MID)
lsb = self._read_u8(_REG_FRF_LSB)
frf = ((msb << 16) | (mid << 8) | lsb) & 0xFFFFFF
frequency = (frf * _FSTEP) / 1000000.0
return frequency
@frequency_mhz.setter
def frequency_mhz(self, val):
assert 290 <= val <= 1020
# Calculate FRF register 24-bit value using section 6.2 of the datasheet.
frf = int((val * 1000000.0) / _FSTEP) & 0xFFFFFF
# Extract byte values and update registers.
msb = frf >> 16
mid = (frf >> 8) & 0xFF
lsb = frf & 0xFF
self._write_u8(_REG_FRF_MSB, msb)
self._write_u8(_REG_FRF_MID, mid)
self._write_u8(_REG_FRF_LSB, lsb)
@property
def encryption_key(self):
"""The AES encryption key used to encrypt and decrypt packets by the chip. This can be set
to None to disable encryption (the default), otherwise it must be a 16 byte long byte
string which defines the key (both the transmitter and receiver must use the same key
value).
# Handle if encryption is disabled.
if self.aes_on == 0:
return None
# Encryption is enabled so read the key and return it.
key = bytearray(16)
self._read_into(_REG_AES_KEY1, key)
return key
@encryption_key.setter
def encryption_key(self, val):
# Handle if unsetting the encryption key (None value).
if val is None:
self.aes_on = 0
# Set the encryption key and enable encryption.
assert len(val) == 16
self._write_from(_REG_AES_KEY1, val)
self.aes_on = 1
@property
def tx_power(self):
"""The transmit power in dBm. Can be set to a value from -2 to 20 for high power devices
(RFM69HCW, high_power=True) or -18 to 13 for low power devices. Only integer power
levels are actually set (i.e. 12.5 will result in a value of 12 dBm).
# Follow table 10 truth table from the datasheet for determining power
# level from the individual PA level bits and output power register.
pa0 = self.pa_0_on
pa1 = self.pa_1_on
pa2 = self.pa_2_on
if pa0 and not pa1 and not pa2:
# -18 to 13 dBm range
return -18 + self.output_power
if not pa0 and pa1 and not pa2:
# -2 to 13 dBm range
if not pa0 and pa1 and pa2 and not self.high_power:
# 2 to 17 dBm range
return -14 + self.output_power
if not pa0 and pa1 and pa2 and self.high_power:
# 5 to 20 dBm range
return -11 + self.output_power
raise RuntimeError("Power amplifiers in unknown state!")
@tx_power.setter
def tx_power(self, val):
val = int(val)
# Determine power amplifier and output power values depending on
# high power state and requested power.
pa_0_on = 0
pa_1_on = 0
pa_2_on = 0
output_power = 0
if self.high_power:
# Handle high power mode.
assert -2 <= val <= 20
if val <= 13:
pa_1_on = 1
output_power = val + 18
elif 13 < val <= 17:
pa_1_on = 1
pa_2_on = 1
output_power = val + 14
else: # power >= 18 dBm
# Note this also needs PA boost enabled separately!
pa_1_on = 1
pa_2_on = 1
output_power = val + 11
# Handle non-high power mode.
assert -18 <= val <= 13
# Enable only power amplifier 0 and set output power.
pa_0_on = 1
# Set power amplifiers and output power as computed above.
self.pa_0_on = pa_0_on
self.pa_1_on = pa_1_on
self.pa_2_on = pa_2_on
self.output_power = output_power
self._tx_power = val
@property
def rssi(self):
"""The received strength indicator (in dBm).
May be inaccuate if not read immediatey. last_rssi contains the value read immediately
receipt of the last packet.
# Read RSSI register and convert to value using formula in datasheet.
return -self._read_u8(_REG_RSSI_VALUE) / 2.0
@property
def bitrate(self):
"""The modulation bitrate in bits/second (or chip rate if Manchester encoding is enabled).
Can be a value from ~489 to 32mbit/s, but see the datasheet for the exact supported
values.
msb = self._read_u8(_REG_BITRATE_MSB)
lsb = self._read_u8(_REG_BITRATE_LSB)
return _FXOSC / ((msb << 8) | lsb)
@bitrate.setter
def bitrate(self, val):
assert (_FXOSC / 65535) <= val <= 32000000.0
# Round up to the next closest bit-rate value with addition of 0.5.
bitrate = int((_FXOSC / val) + 0.5) & 0xFFFF
self._write_u8(_REG_BITRATE_MSB, bitrate >> 8)
self._write_u8(_REG_BITRATE_LSB, bitrate & 0xFF)
@property
def frequency_deviation(self):
"""The frequency deviation in Hertz."""
msb = self._read_u8(_REG_FDEV_MSB)
lsb = self._read_u8(_REG_FDEV_LSB)
return _FSTEP * ((msb << 8) | lsb)
@frequency_deviation.setter
def frequency_deviation(self, val):
assert 0 <= val <= (_FSTEP * 16383) # fdev is a 14-bit unsigned value
# Round up to the next closest integer value with addition of 0.5.
fdev = int((val / _FSTEP) + 0.5) & 0x3FFF
self._write_u8(_REG_FDEV_MSB, fdev >> 8)
self._write_u8(_REG_FDEV_LSB, fdev & 0xFF)
def send(
self,
data,
keep_listening=False,
destination=None,
node=None,
identifier=None,
flags=None
"""Send a string of data using the transmitter.
You can only send 60 bytes at a time
(limited by chip's FIFO size and appended headers).
This appends a 4 byte header to be compatible with the RadioHead library.
The header defaults to using the initialized attributes:
(destination,node,identifier,flags)
It may be temporarily overidden via the kwargs - destination,node,identifier,flags.
Values passed via kwargs do not alter the attribute settings.
The keep_listening argument should be set to True if you want to start listening
automatically after the packet is sent. The default setting is False.
Returns: True if success or False if the send timed out.
# Disable pylint warning to not use length as a check for zero.
# This is a puzzling warning as the below code is clearly the most
# efficient and proper way to ensure a precondition that the provided
# buffer be within an expected range of bounds. Disable this check.
# pylint: disable=len-as-condition
assert 0 < len(data) <= 60
# pylint: enable=len-as-condition
self.idle() # Stop receiving to clear FIFO and keep it clear.
# Fill the FIFO with a packet to send.
# Combine header and data to form payload
payload = bytearray(4)
if destination is None: # use attribute
payload[0] = self.destination
else: # use kwarg
payload[0] = destination
if node is None: # use attribute
payload[1] = self.node
else: # use kwarg
payload[1] = node
if identifier is None: # use attribute
payload[2] = self.identifier
else: # use kwarg
payload[2] = identifier
if flags is None: # use attribute
payload[3] = self.flags
else: # use kwarg
payload[3] = flags
payload = payload + data
# Write payload to transmit fifo
self._write_fifo_from(payload)
# Turn on transmit mode to send out the packet.
self.transmit()
# Wait for packet sent interrupt with explicit polling (not ideal but
# best that can be done right now without interrupts).
start = time.time()
timed_out = False
while not timed_out and not self.packet_sent:
if (time.time() - start) >= self.xmit_timeout:
timed_out = True
# Listen again if requested.
if keep_listening:
self.listen()
else: # Enter idle mode to stop receiving other packets.
self.idle()
return not timed_out
def send_with_ack(self, data):
"""Reliable Datagram mode:
Send a packet with data and wait for an ACK response.
The packet header is automatically generated.
If enabled, the packet transmission will be retried on failure
if self.ack_retries:
retries_remaining = self.ack_retries
retries_remaining = 1
got_ack = False
self.sequence_number = (self.sequence_number + 1) & 0xFF
while not got_ack and retries_remaining:
self.identifier = self.sequence_number
self.send(data, keep_listening=True)
# Don't look for ACK from Broadcast message
if self.destination == _RH_BROADCAST_ADDRESS:
got_ack = True
# wait for a packet from our destination
ack_packet = self.receive(timeout=self.ack_wait, with_header=True)
print("got return before ack conf " + str(ack_packet))
if ack_packet is not None:
print("got ack " + str(ack_packet))
if ack_packet[3] & _RH_FLAGS_ACK:
# check the ID
if ack_packet[2] == self.identifier:
got_ack = True
break
# pause before next retry -- random delay
if not got_ack:
# delay by random amount before next try
time.sleep(self.ack_wait + self.ack_wait * random.random())
retries_remaining = retries_remaining - 1
# set retry flag in packet header
self.flags |= _RH_FLAGS_RETRY
self.flags = 0 # clear flags
return got_ack
# pylint: disable=too-many-branches
def receive(
self, *, keep_listening=True, with_ack=False, timeout=None, with_header=False
"""Wait to receive a packet from the receiver. If a packet is found the payload bytes
are returned, otherwise None is returned (which indicates the timeout elapsed with no
reception).
If keep_listening is True (the default) the chip will immediately enter listening mode
after reception of a packet, otherwise it will fall back to idle mode and ignore any
future reception.
All packets must have a 4 byte header for compatibilty with the
RadioHead library.
The header consists of 4 bytes (To,From,ID,Flags). The default setting will strip
the header before returning the packet to the caller.
If with_header is True then the 4 byte header will be returned with the packet.
The payload then begins at packet[4].
If with_ack is True, send an ACK after receipt (Reliable Datagram mode)
timed_out = False
if timeout is None:
timeout = self.receive_timeout
if timeout is not None:
# Wait for the payload_ready signal. This is not ideal and will
# surely miss or overflow the FIFO when packets aren't read fast
# enough, however it's the best that can be done from Python without
# interrupt supports.
# Make sure we are listening for packets.
self.listen()
start = time.time()
timed_out = False
while not timed_out and not self.payload_ready:
if (time.time() - start) >= timeout:
timed_out = True
# Payload ready is set, a packet is in the FIFO.
packet = None
# save last RSSI reading
self.last_rssi = self.rssi
self.idle()
if not timed_out:
# Read the length of the FIFO.
fifo_length = self._read_u8(_REG_FIFO)
# Handle if the received packet is too small to include the 4 byte
# RadioHead header and at least one byte of data --reject this packet and ignore it.
if fifo_length > 0: # read and clear the FIFO if anything in it
#packet = bytearray(fifo_length)
packet = bytearray(21)
self._read_into(_REG_FIFO, packet)
if fifo_length < 5:
packet = None
if (
self.node != _RH_BROADCAST_ADDRESS
and packet[0] != _RH_BROADCAST_ADDRESS
and packet[0] != self.node
packet = None
# send ACK unless this was an ACK or a broadcast
elif (
with_ack
and ((packet[3] & _RH_FLAGS_ACK) == 0)
and (packet[0] != _RH_BROADCAST_ADDRESS)
# delay before sending Ack to give receiver a chance to get ready
if self.ack_delay is not None:
time.sleep(self.ack_delay)
# send ACK packet to sender
data = bytes("!", "UTF-8")
self.send(
data,
destination=packet[1],
node=packet[0],
identifier=packet[2],
flags=(packet[3] | _RH_FLAGS_ACK),
# reject Retries if we have seen this idetifier from this source before
if (self.seen_ids[packet[1]] == packet[2]) and (
packet[3] & _RH_FLAGS_RETRY
packet = None
else: # save the packet identifier for this source
self.seen_ids[packet[1]] = packet[2]
if (
not with_header and packet is not None
): # skip the header if not wanted
packet = packet[4:]
# Listen again if necessary and return the result packet.
if keep_listening:
self.listen()
self.idle()
print("rec packet: "+str(packet))
return packet
