ADC only possible with Pins 32 - 39?
mnvk52
Post by mnvk52 » Sun Sep 06, 2020 12:39 pm
the manual says
On the ESP32, ADC functionality is available on Pins 32, 33, 34, 35, 36, 37, 38, and 39.
https://micropython-docs-esp32.readthed ... conversion
My device has more pins available for ADC: https://joy-it.net/files/files/Produkte ... 200320.pdf
How can I read pin 4? This way doesn't work:
from machine import Pin, ADC
print(ADC(Pin(4)).read())
%Run pin4read.py
  File "/home/pin4read.py", line 2, in <module>
ValueError: invalid Pin for ADC
rpr
Re: ADC only possible with Pins 32 - 39?
Post by rpr » Sun Sep 06, 2020 5:06 pm
Those other pins are connected to ADC2 which is not currently supported. Part of the reason might be that ADC2 cannot be used when WiFi is active. In principle, it might be possible for someone to write/modify the micropython ADC driver to support the ADC2.
https://docs.espressif.com/projects/esp ... s/adc.html
rcolistete
Post by rcolistete » Sun Sep 06, 2020 9:42 pm
See "MicroPython_ESP32_psRAM_LoBo" firmware, which supports ADC2.
