Try Multiple WIFI Connections
Expert
Post by Expert » Tue Sep 08, 2020 8:33 pm
I would like to keep trying a list of WIFI connections until the ESP32 connects to one. Here is what I have but I keep getting the no AP found error. If I just use one of them it connects fine. I know there is a better way. Any help is appreciated.
import esp32
from machine import Pin, ADC, reset
SSID1 = "firstAP"
PASSWORD1 = "letmein"
SSID2 = "secondAp"
PASSWORD2 = "letmein"
SSID3 = "thirdAP"
PASSWORD3 = "letmein"
SSID4 = "fourthAP"
PASSWORD4 = "letmein"
def do_connect():
    if not sta_if.isconnected():
        sta_if.active(True)
        sta_if.connect(SSID1, PASSWORD1)
        while not sta_if.isconnected():
            pass
        sta_if.active(True)
        sta_if.connect(SSID2, PASSWORD2)
            pass
        sta_if.active(True)
        sta_if.connect(SSID3, PASSWORD3)
            pass
        sta_if.active(True)
        sta_if.connect(SSID4, PASSWORD4)
            pass
    print('network config:', sta_if.ifconfig())
do_connect()
Re: Try Multiple WIFI Connections
Post by dhylands » Tue Sep 08, 2020 9:13 pm
Just looking at the logic, if it doesn't connect to the first AP, then it's going to get stuck at the while pass loop at the end of connecting to the first AP. You probably need a timeout, and if it fails to connect after say 10 seconds (or whatever is appropriate) then continue on to try the next SSID/password.
Rather than duplicating the logic, I'd probably create an array of SSIDs and passwords and use a loop to iterate over the list of SSID and passwords.
Expert
Post by Expert » Tue Sep 08, 2020 11:05 pm
I'll give it a try. Thanks.
Divergentti
Post by Divergentti » Fri Oct 16, 2020 7:07 am
I have strugled with this too and tried to solve multiple WIFI AP problem with this type of boot.py https://github.com/divergentti/kotiauto ... in/boot.py
This works mostly OK, but sometimes ESP boots several times and during boot I see error "I (4408) wifi: STA_DISCONNECTED, reason:202 authentication failed". I have no idea why that happens, because credentials are the same all the time and authentication works anyways after reboot (which my script does if connection fails).
MODIFY: I figured this out. I had to check what was boot reason and if reason was 1, 2 or 4, then skip WiFi setups, because we are already connected.
