Modbus on ESP32
Duality
Modbus on ESP32
Post by Duality » Fri Oct 02, 2020 7:23 am
Hi all,
I am new to Modbus on RS485 and trying to build Micropython code for Modbus RTU slave and master. I have gone through pycom modbus library and tried it. However, I couldnt get any success. I feel that there might be some issue in my connections. So I want to get some expert advice from you all.
My connections are:
Esp32 (tx=17, rx=16, 3.3v, GND and GPIO4 - as RTS) :arrow: SP3485 (breakout board from Sparkfun) :arrow: Connected to PC through a USB to RS485 converter.
My PC is running the slave and master simulator as and when needed. I have built my own code as well (inspired from pycom modbus library). This is given below:
import functions
import machine, time
import const
# 16bit CRC -> 8 byte: addr, fc, 00,register_addr,00,number of registers to read,CRC LSB, CRC MSB
#setup serial connection
def send_receive(pdu):
ctrl_pin.value(1)
time.sleep(0.01)
uart.write(pdu)
ctrl_pin.value(0)
time.sleep(0.01)
print('received: ', uart.read())
time.sleep(0.1)
def create_req_pdu(slave_addr,fc,register_addr, register_count):
pdu = bytearray()
pdu.append(slave_addr)
pdu.append(fc)
pdu.append(0x00)
pdu.append(register_addr)
pdu.append(0x00)
pdu.append(register_count)
pdu.extend(functions.calculate_crc16(pdu))
print('request pdu: ', pdu)
return pdu
def get_request_pdu():
ctrl_pin.value(0)
req = uart.read()
print('req: ')
time.sleep(0.5)
uart = UART(1,tx=17,rx=16,baudrate=9600,parity=None,stop=1)
ctrl_pin = machine.Pin(4,machine.Pin.OUT)
slave_addr=0x01
fc=const.READ_HOLDING_REGISTERS
register_addr=0x00
register_count = 0x0A
send_receive(create_req_pdu(slave_addr,fc,register_addr,register_count))
What am I missing here?
Thanks and regards.
Duality
Re: Modbus on ESP32
Post by Duality » Tue Oct 06, 2020 5:53 am
It work now! :)
I checked with the oscilloscope and saw that the transmission voltage levels were very weak. I changed the MAX485 and now, it is working great. Although, now I have run into other issues. :|
chiasang
Re: Modbus on ESP32
Post by chiasang » Tue May 18, 2021 5:28 am
Same issue I have, I know the const lib in your code, could you tell me about the lib name of const. or how to read holdingregisters,thx
BetterAutomations
Re: Modbus on ESP32
Post by BetterAutomations » Tue Jun 08, 2021 10:59 pm
I'm going to attempt an answer even though I've never used Duality's library. I'm guessing const is just a file with constants in it. Something like this.
# const.py
# This value is entirely guessed, just for an example
READ_HOLDING_REGISTERS=0xFFF
