I have one big problem. I have working code but if I want doing anything else as writing or reading json files ESP give me Memory error.
I try using minimal code but for all sensors and sending data via uart have using many memory.
I think about frozen code because I need use many lists and cant using standart allocated buffers.
Have someone tutorial how create frozen code of micropython? My project is almoust done but if I save many data to file or reading data from sd card program will fall.
Many thanks for answers
ESP32 DevKit - Frozen code
Re: ESP32 DevKit - Frozen code
https://github.com/peterhinch/micropyth ... -manifests
The simplest way is to make your own board definition and compile MicroPython using that board definition. The TinyPico is a good example https://github.com/micropython/micropyt ... s/TINYPICO
Note that the board definition folder doesn't have to be inside the MicroPython repo.
