issue waking from Pin change
seandepagnier
Post by seandepagnier » Mon Oct 05, 2020 12:49 am
when I try to use ext1:
MicroPython v1.9.4 on 2018-05-11; ESP32 module with ESP32
>>> from machine import Pin
>>> p=Pin(12, Pin.IN, Pin.PULL_UP)
>>> import esp32
>>> esp32.wake_on_ext1((p,), esp32.WAKEUP_ALL_LOW)
>>> import machine
>>> machine.deepsleep()
It just resets immediately and does not wait for the pin to get pulled low like ext0 does
seandepagnier
Re: issue waking from Pin change
Post by seandepagnier » Mon Oct 05, 2020 2:06 am
it works if the pulldown is used and the change is when the pin is high, but not the other way around
