Save data to flash
Jurkylius
Save data to flash
Post by Jurkylius » Mon Oct 05, 2020 5:25 am
now I using json config file to save some settings but after when I write too many data to file I have problem with memory.
Can I read only specific row in file and not whole file?
I rewrite some library from arduino c and want open dict of specific key. See next:
def begin(self, key, readOnly = True):
        self.readOnly = readOnly
        if(self.data == None):
            with open(self.fileName, 'r') as data_file:
                self.data = ujson.loads(data_file.read())
                data_file.close()
        if(self.data != None):
            self.key = key
            self.actualData = self.data[key]
            if(self.actualData != None):
                return True
        return False
Re: Save data to flash
Post by dhylands » Mon Oct 05, 2020 4:42 pm
The JSON file format doesn't really lend itself to reading just one particular entry.
You really want a file format (probably binary) where each entry takes up the same amount of space. Then if you want entry 15, you can calculate the offset within the file where entry 15 starts and read a single entry into memory.
Even if you used a streaming JSON reader, updating an entry would also be problematic (you'd wind up having to read/write) the entire file.
Using a binary format where each entry takes up the same amount of space, allows for updates which don't require reading/writing the entire file.
Post by pythoncoder » Tue Oct 06, 2020 5:27 pm
I think your answer may be the btree module which enables you to create a dictionary on a filesystem and efficiently access it by key.
If you must encode a dict there are more efficient ways than JSON: see my comments on Protocol Buffers here. This also discusses `ustruct` which is a way to write pure binary fixed record size data as recommended by @dhylands. JSON is designed to be human readable and is not efficient. CPython's Pickle is much better (non human-readable), but MicroPython's is not.
A fixed record size binary file implies replacing the dict with a set of key-value pairs and iterating over them until you match your key - unless you have a means of computing the offset from the key, in which case you only need to store the values and it becomes highly efficient. This works well with highly structured data such as bitmapped fonts.
I suspect that your data may not be amenable to fixed size records.
If, even with better encoding, the dict is still too big then you'll have to consider other data structures which can be read incrementally such as key-value pairs. Or perhaps the dict could be split into several smaller ones. You trade substantially longer access time for smaller RAM usage.
Jurkylius
Post by Jurkylius » Fri Oct 16, 2020 10:52 am
Thanks for answers.
I try using btree database and have problem with save data.
Than I want ask for write mode. If I use open with "w+b" mode than I save new data and can update existing or .. ?
I create simple data library.
import btree
class DataThree:
    database = None
    file = None
    actualKey = None
    def __init__(self):
        pass
    def openDatabase(self, readMode):
        if not readMode:
            self.file = open("config","w+b")
                self.file = open("config","r+b")
            except OSError:
        self.database = btree.open(self.file)
        return True if self.database != None else False
    def begin(self,key,readMode = True):
        self.actualKey=key
        return self.openDatabase(readMode)
    def put(self,key,data):
        if(self.database != None):
            self.database[(self.actualKey+key).encode("utf-8")] = data.encode("utf-8") if type(data) is str else str(data).encode("utf-8")
            print('Databaza sa nenasla!')
    def getString(self,key):
                if(self.database[(self.actualKey+key).encode("utf-8")] in self.database):
                    return self.database[(self.actualKey+key)].decode("utf-8")
        except KeyError:
            return None
    def getInt(self,key,defaultValue=None):
        data = self.getString(key)
        if(data != None):
            return int(self.getString(key))
            return defaultValue
    def getBool(self,key,defaultValue=None):
        if(data != None):
            return data.lower() in ("true","yes","t","1")
            return defaultValue
    def end(self):
        self.database.flush()
        self.database.close()
        self.file.close()
After I use save data:
if(pref.begin(definition.TYPE_DAY_NIGHT.lower(), False)):
     pref.put("hour_on", self.hourOpk)
     pref.put("min_on", self.minOpk)
     pref.put("hour_off", self.hourCyk)
     pref.put("min_off", self.minCyk)
     pref.end()
Post by jimmo » Tue Oct 20, 2020 6:22 am
Yes, the "+" in "w+b" is "update" mode which avoids the file being truncated.
