newbie issue with i2c
crowhill67
Post by crowhill67 » Thu Oct 08, 2020 4:37 pm
I want to connect an MPU6050 to a doit ESP32 devkit v1. I have hooket up theMPU as follows:
ESP32 MPU
GPIO22 ---> scl
GPIO21 ---> sda
3v3 ---> vcc
gnd ---> gnd
my code in the repl is very simple:
from machine import I2C, Pin
i2c = I2C(scl=Pin(22), sda=Pin(21)
i2c.scan()
This results in all i2c addresses being displayed, not the expected 0x68.
does anyone have an idea what is going wrong?
Regards,
dave.
Re: newbie issue with i2c
Post by Roberthh » Thu Oct 08, 2020 4:41 pm
Looks like the pullup resistors are missing.
crowhill67
Post by crowhill67 » Thu Oct 08, 2020 4:47 pm
Thanks for your reply,
I was wondering if that was the case, and I added two resistors (10K) from both the scl and sda to 3v3, but I am having the same issue.
Dave.
Post by Roberthh » Thu Oct 08, 2020 6:05 pm
Have you any means to check the state of the SDA and SCL line, either static (multimeter) or dynamic (logc analyzer). The efffect you see is typically caused by the SDA line constant low.
crowhill67
Post by crowhill67 » Thu Oct 08, 2020 7:15 pm
Hi Robert,
the sda line seems to be high (3.27v) according to my not so accurate mulitmeter. The thing is I have swapped out the MPU6050 for a HMC5883L, and the problem persists, so I don't think it is the MPU. I will try a different board.
thanks for the help sofar, if you think of anything else i would appreciate it!
regards,
dave.
Post by Roberthh » Thu Oct 08, 2020 7:29 pm
For problems like this a simple logic analyzer works well, which are sold for about 12€ e.g. at Amazon, https://www.amazon.com/-/de/dp/B07K6HXD ... 237&sr=8-5
It gives you an insight of what happens instead of guessing. It works together with the Saleae "Logic" software or the public domain "pulseview".
Post by OutoftheBOTS_ » Fri Oct 09, 2020 1:52 am
I have set both pins to input pullup before setting up the I2C has fixed this problem in the past.
Post by Roberthh » Fri Oct 09, 2020 6:06 am
@OutoftheBOTS_ That would help if there are no external pull-up resistors present. But if I understand the poster correct, there are some installed. So I think it's still a problem with the connection.
@crowhill67: Did you check/change the wires connecting the MPU? How long are these wires? I2C only works with short wires. You can also try a low freq setting, like freq=1000.
crowhill67
Post by crowhill67 » Fri Oct 09, 2020 9:20 am
the wires are bout 5cm (2 inches), I will try a lower frequequency.
crowhill67
Post by crowhill67 » Fri Oct 09, 2020 3:50 pm
I have asked Santa for one :-)
