BetterAutomations
Post by BetterAutomations » Wed Mar 30, 2022 2:12 am
So is pairing an accessory device without encryption as simple as this?
Accessory:
broadcast = b'\xff\xff\xff\xff\xff\xff'
add_peer(broadcast)
send(broadcast, '')
Central:
peer = irecv()[0]
add_peer(peer)
BetterAutomations
Post by BetterAutomations » Wed Mar 30, 2022 4:10 am
Just tested it. I was almost correct.
Accessory:
from esp import espnow
w0=network.WLAN(network.STA_IF)
w0.active(True)
e = espnow.ESPNow()
e.init()
e.add_peer(broadcast)
e.send(broadcast, 'Hello')
Central:
w0.active(True)
e = espnow.ESPNow()
e.init()
    host, msg = e.irecv()
    if msg:
        e.add_peer(host)
        break
Accessory:
>>> w0.config('mac')
b'\xe0\xe2\xe6L\x19\xf4'
Central:
>>> e.get_peers()
((b'\xe0\xe2\xe6L\x19\xf4', b'\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00', 0, 0, False),)
BetterAutomations
Post by BetterAutomations » Wed Mar 30, 2022 5:02 pm
Help? When I compile the firmware, the esp module doesn't seem to include espnow. I got it working with precompiled binaries (above) but not when I compile.
rst:0x1 (POWERON_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0018,len:4
load:0x3fff001c,len:4252
load:0x40078000,len:12500
load:0x40080400,len:3392
entry 0x4008060c
could not find module '_boot.py'
MicroPython v1.13-1283-gc768704cf-dirty on 2022-03-30; 8MB/OTA/ESPNow module with ESP32
ImportError: can't import name espnow
Here's the steps I took to compile for my WROVER with 8MB SPIRAM and 8MB flash:
# git clone glenn20's code
. $HOME/esp-idf/export.sh
cd ~/glenn20/ports/esp32/
vi boards/GENERIC_OTA/mpconfigboard.h
# Change this #define:
#define MICROPY_HW_BOARD_NAME "8MB/OTA/ESPNow module with ESP32"
vi boards/GENERIC_OTA/sdkconfig.board
CONFIG_BOOTLOADER_APP_ROLLBACK_ENABLE=y
CONFIG_PARTITION_TABLE_CUSTOM=y
CONFIG_PARTITION_TABLE_CUSTOM_FILENAME="partitions-ota.csv"
CONFIG_ESPTOOLPY_FLASHSIZE_8MB=y
CONFIG_ESP32_SPIRAM_SUPPORT=y
CONFIG_SPIRAM_CACHE_WORKAROUND=y
CONFIG_SPIRAM_IGNORE_NOTFOUND=y
CONFIG_SPIRAM_USE_MEMMAP=y
vi partitions-ota.csv
# Set up that as I always do
export FLASH_SIZE=8MB
export BOARD=GENERIC_OTA
make clean
make
Last edited by BetterAutomations on Wed Mar 30, 2022 6:16 pm, edited 1 time in total.
BetterAutomations
Post by BetterAutomations » Wed Mar 30, 2022 5:08 pm
I think I see why. I cloned glenn20's MicroPython fork which I assumed contained his ESPnow code, but it does not. I'll try to merge from his pull request instead.
Edit: Confirmed, that was the problem. I can now import espnow.
cdevidal@ubuntuvm:~/glenn20/ports/esp32$ ls ~/glenn20/docs/library/espnow.rst
ls: cannot access '/home/cdevidal/glenn20/docs/library/espnow.rst': No such file or directory
BetterAutomations
Post by BetterAutomations » Thu Mar 31, 2022 7:54 pm
Anyone have a problem with intermittent firing of on_recv callbacks? Mine intermittently work, even with a bare minimum implementation. I'm working on dynamic pairing with an unencrypted peer.
Central:
def cb(espn):
    while espn.poll():
        print(repr(espn.irecv()))
w0.active(True)
espn = espnow.ESPNow()
espn.config(on_recv=cb)
espn.init()
Accessory:
w0.active(True)
espn.init()
espn.add_peer(broadcast)
Send a message:
>>> espn.send(broadcast, 'Test')
True
Central just ignores it:
But sometimes after a hard reset, it works:
>>> (bytearray(b'4\xab\x95ZU`'), bytearray(b'Test'))
BetterAutomations
Post by BetterAutomations » Thu Mar 31, 2022 9:47 pm
Edit: Not caused by ESP-Now code. See this bug report. Solution: Use ESP-IDF 4.2+.
WARNING! The code from the PR "bricked" (broke the wifi radio) on two different ESP32s. (ESP32-WROVER-IE 8MB and ESP32-WROVER-E 16MB.) It starts with the errors below on wlan.connect(). The first time I got it, I couldn't fix it. I counted that chip as dead. Tried again with a second chip, and I got these errors again. I ran erase_flash and flashed it to the standard esp32spiram-20220117-v1.18.bin, unplugged from USB, and it came back to life.
Happened a third time and the second ESP32 is also now bricked (no wifi) :(
Edit: I tried both ESP32 again and both are now functional, after several unplugs and plugs. So it appears to only brick them for a few minutes or hours, or requires several unplugs.
E (45979) wifi:esf_buf: t=2 l=76 max:32, alloc:32 no eb, TXQ_BLOCK=0
W (45979) wifi:alloc eb len=76 type=2 fail, heap:151108
W (45979) wifi:m f probe req l=0
E (46099) wifi:esf_buf: t=2 l=76 max:32, alloc:32 no eb, TXQ_BLOCK=0
W (46099) wifi:alloc eb len=76 type=2 fail, heap:151108
W (46099) wifi:m f probe req l=0
E (46229) wifi:esf_buf: t=2 l=76 max:32, alloc:32 no eb, TXQ_BLOCK=0
W (46229) wifi:alloc eb len=76 type=2 fail, heap:151108
W (46229) wifi:m f probe req l=0
E (47079) wifi:esf_buf: t=2 l=76 max:32, alloc:32 no eb, TXQ_BLOCK=0
W (47079) wifi:alloc eb len=76 type=2 fail, heap:151184
W (47079) wifi:m f probe req l=0
E (48809) wifi:esf_buf: t=2 l=76 max:32, alloc:32 no eb, TXQ_BLOCK=0
W (48809) wifi:alloc eb len=76 type=2 fail, heap:151108
W (48809) wifi:m f probe req l=0
E (48939) wifi:esf_buf: t=2 l=76 max:32, alloc:32 no eb, TXQ_BLOCK=0
W (48939) wifi:alloc eb len=76 type=2 fail, heap:151108
W (48939) wifi:m f probe req l=0
E (49059) wifi:esf_buf: t=2 l=76 max:32, alloc:32 no eb, TXQ_BLOCK=0
W (49059) wifi:alloc eb len=76 type=2 fail, heap:151108
W (49059) wifi:m f probe req l=0
E (49189) wifi:esf_buf: t=2 l=76 max:32, alloc:32 no eb, TXQ_BLOCK=0
W (49189) wifi:alloc eb len=76 type=2 fail, heap:151108
W (49189) wifi:m f probe req l=0
E (49309) wifi:esf_buf: t=2 l=76 max:32, alloc:32 no eb, TXQ_BLOCK=0
W (49309) wifi:alloc eb len=76 type=2 fail, heap:151108
W (49309) wifi:m f probe req l=0
E (49439) wifi:esf_buf: t=2 l=76 max:32, alloc:32 no eb, TXQ_BLOCK=0
W (49439) wifi:alloc eb len=76 type=2 fail, heap:151108
W (49439) wifi:m f probe req l=0
E (50279) wifi:esf_buf: t=2 l=76 max:32, alloc:32 no eb, TXQ_BLOCK=0
W (50279) wifi:alloc eb len=76 type=2 fail, heap:151052
W (50279) wifi:m f probe req l=0
I then ran erase_flash and flashed it to the standard esp32spiram-20220117-v1.18.bin, unplugged from USB, but now it's bricked :(
MicroPython v1.18 on 2022-01-17; ESP32 module (spiram) with ESP32
>>> import network
>>> sta_if = network.WLAN(network.STA_IF)
>>> sta_if.active(True)
>>> sta_if.connect('My SSID', 'Passphrase')
E (83336) wifi:sta is connecting, return error
OSError: Wifi Internal Error
Last edited by BetterAutomations on Mon Apr 11, 2022 12:19 pm, edited 2 times in total.
davef
Post by davef » Fri Apr 01, 2022 12:57 am
I often see this error:
when my ESP32 Generic runs someone else program that only has a boot.py and a main.py
A hard reset sorts it then I shift most of the code in main to my_program.py and problem goes away.
Haven't seen this with any ESPNow on Generic.
By "bricked" do you mean the hardware is no longer useful?
BetterAutomations
Post by BetterAutomations » Fri Apr 01, 2022 1:25 am
Central:
def cb(espn):
    while espn.poll():
w0.active(True)
espn.init()
Accessory:
w0.active(True)
espn.init()
Send a message:
True
Hmm. Not just callbacks. Central is intermittently not responding at all.
Central:
MicroPython v1.17-277-gb67384616-dirty on 2022-03-30; 8MB/OTA/ESPNow module with ESP32
>>> import network
>>> w0.active(True)
True
>>> espn.init()
>>> espn.irecv()
Accessory:
>>> while True:
...     espn.send(broadcast, 'Testing')
...     sleep(1)
True
True
True
Might? be hardware. When I reversed the hardware, the accessory is struggling to send, only occasionally gets through.
>>> while True:
...     espn.send(broadcast, 'Test')
...     sleep(1)
False
False
True
False
False
False
False
davef
Post by davef » Fri Apr 01, 2022 2:21 am
The documentation says he has put a RSSI function in, but check his GitHub as I am not sure it has made its way into images.
BetterAutomations
Post by BetterAutomations » Fri Apr 01, 2022 2:39 am
It was, yes. Even flashing to standard unmodified official uPy firmware binaries, I could no longer connect to WiFi. Pull the device off for some time and it resets itself and eventually starts working again. I don't know what's going on. Found a third ESP32 and am testing with that now. So far it hasn't bricked it. I could blame it on faulty hardware if one chip bricked, but a second bricked in exactly the same way.
And by the way, it bricked when using no one's code. Was just pasting raw commands into the REPL. See above.
