Page 26 of 37
Re: ESP-Now support for ESP32 (and ESP8266)
Posted: Thu May 19, 2022 9:41 am
by glenn20
Lucje wrote: ↑Wed May 18, 2022 5:34 pm
The only problem I'm having at this moment is: when I boot the little board, and it loads the program with the espnow in it, it crashes.
Is this a normal thing at this moment?
I am going to guess that when you say "crash", you mean that the esp32 reboots with something like the message "Guru mediation error"
While it is possible that is a software problem or a glitch that can be worked around, it is also true that sometimes this can happen when your power supply does not provide enough power for the esp32. When you turn on the radio it can use a lot more power (it is still small compared to mobile phones, but it uses a lot more power with the radio on - especially when the radio first turns on.
I don't know that is your problem - but I have had this problem in the past when I was using one particular power supply that was enough to support the esp32 with the radio off, but when it turned on - the spike in current was too much for my anemic little power supply and the board would reboot.
So, before investing a time in chasing possible software problems check it with a beefier power supply.
Posted: Thu May 19, 2022 9:56 am
by Lucje
glenn20 wrote: ↑Thu May 19, 2022 9:41 am
Sorry I'm not always clear in my questions (I always have this problem). I will do my best to avoid this.
If I plug the ESP into my pc and connect (and the EspNow things are loaded with it), it crashes and I have to re-burn the firmware.
I'm going to study the power problem and keep you informed of the result.
Thank you for your reply.
Greetings Lucje
Posted: Thu May 19, 2022 10:12 am
by davef
If you have a standard Micropython v1.18 image on the ESP32 and plug it into your PC and run a simple program it runs OK?
I have never used
uPyCraft V1.1
are you following something like this
https://randomnerdtutorials.com/flash-u ... 2-esp8266/?
I would expect a PC USB port to be able to handle an ESP32. I had situations when using a ESP8266 with having to re-load the firmware. I think the programs were just too big, moving to an ESP32 and that problem disappeared.
Posted: Thu May 19, 2022 10:23 am
by Lucje
davef wrote: ↑Thu May 19, 2022 10:12 am
I have never used
uPyCraft V1.1
It runs ok when start it without the EspNow. Both firmware's (the standard and the Generic for the EspNow)
When I load it fresh to the board and start the script, it goes fine.
But it's not a good think to have to plug in the pc to make it work
And it's is Esp32, it should be strong enough...
Posted: Thu May 19, 2022 10:31 am
by Lucje
In the meantime I have looked at the power problem. Even with an extra power supply the problem is still there.
Assume that it must really go wrong during boot.
This is my boot script:
import esp
import os
files=os.listdir()
if len(files)>=2:
print('The device have %d files'%int(len(files)-1))
for i in range(len(files)):
if files[i]!='boot.py':
print('file name:',files[i])
exec(open(files[i]).read(),globals()) #Here the other .py files get loaded.
print('Ok!')
except:
print("Syntax error!")
print("MicroPython has no files!")
It always has worked except now.
Posted: Thu May 19, 2022 10:45 am
by davef
By "without the ESPNow" do you mean when not doing
Does your IDE actually download the files on to the ESP32 or run them from the IDE?
Posted: Thu May 19, 2022 10:46 am
by davef
Are you hitting the EN button after you have downloaded the files and removed the USB connection?
Posted: Thu May 19, 2022 10:57 am
by davef
I would not run a program like that in boot.py.
Leave boot.py with nothing in it.
In main.py
in my_program.py put your wanted program.
Putting that code in boot.py and something goes wrong I am pretty certain that you will not be told what happened.
Posted: Sat May 21, 2022 9:51 am
by Lucje
davef wrote: ↑Thu May 19, 2022 10:46 am
When it runs, I can pull the USB out and it keeps running (on battery power), as long I don't reboot or reset.
Posted: Sat May 21, 2022 10:42 am
by Lucje
davef wrote: ↑Thu May 19, 2022 10:45 am
No, I mean loading MyProgram.py where I use code for EspNow.
Yes it does. I't wouldn't work when I pull the USB while still it keeps running on the battery. (12V battery (12LS.1.2) converted to 5V)
