I am using microdot as webserver in esp32, it includes some static files like css,js and html etc.
Can i make the static files to new firmware of esp32?
I succeeds make some .py files to the firmware, just copy it in ~/esp/micropython/ports/esp32/modules,and make it well.
But when i copy the css and js files to it ,make error:
Building with ESP IDF v3
warn: unsupported file type, skipped freeze: web/jquery-3.5.1.min.js
Make the css and html files to firmware
Re: Make the css and html files to firmware
Hello, can you tell me how do you did it?
I am tring to do the same. I have a microdot server and I want to make it all in a bin file. But I cant froze the static files.
Thanks.
Thanks.
