This is interesting topic.
I am about to begin my indoorairquality measurement setup.
Meanwhile I am waiting components to arrive, I implemented simple OLED (SPI) and CCS811 sensor script.
Later I will replace CCS811 with NIR (MH-Z19) and add either AHT10 or BMP280 for temp and rh and when those are up and running, I liike to implement user friendly, touch screen version of the gadget. In that phase I will give a try for lcd160cr.
In this simple test case I am using Pin21 for SCL and Pin22 for SDA in i2c for the sensor and it seems to work fine without timeouts.
You seem to have freq=1_000_000. I use only 400000. Perhaps that is causing timeouts?
OLED näytölle: sh1160-kirjastoa, jonka voit ladata täältä https://github.com/robert-hh/SH1106
CCS811 sensorille: https://github.com/Notthemarsian/CCS811/blob/master/CCS811.py
Näytön SPI kytkentä esimerkki:
SSD1306 NodeMCU-32S(ESP32)
GND ----> GND
VCC ----> 3v3 (3.3V)
D0 ----> GPIO 18 SCK (SPI Clock)
D1 ----> GPIO 23 MOSI (sama kuin SDA)
RES ----> GPIO 17 Reset
DC ----> GPIO 16 Data/Command select
CS ----> GPIO 5 Chip Select
I2C kytkentä esimerkki:
SCL = 22
SDA = 21
CCS811 muista kytkeä nWake -> GND!
from machine import I2C, SPI, Pin
import sh1106
import ccs811
import uasyncio as asyncio
import utime
import esp32
class SPI_naytonohjain():
def __init__(self, res=17, dc=16, cs=5, sck=18, mosi=23, leveys=16, rivit=6, lpikselit=128, kpikselit=64):
self.rivit = []
self.nayttotekstit = []
self.aika = 5 # oletusnäyttöaika
""" Muodostetaan näytönohjaukseen tarvittavat objektit """
# SPI-kytkennan pinnit
self.res = Pin(res) # reset
self.dc = Pin(dc) # data
self.cs = Pin(cs) # chip select
# SPI-objektin luonti, sck = d0, mosi = SDA
self.spi = SPI(2, baudrate=115200, sck=Pin(sck), mosi=Pin(mosi))
# naytto-objektin luonti
self.nayttoleveys = leveys # merkkiä
self.nayttorivit = rivit # riviä
self.pikselit_leveys = lpikselit # pikseliä
self.pikselit_korkeus = kpikselit
self.naytto = sh1106.SH1106_SPI(self.pikselit_leveys, self.pikselit_korkeus, self.spi, self.dc,
self.res, self.cs)
self.naytto.poweron()
self.naytto.init_display()
self.kaanteinen = False
async def pitka_teksti_nayttoon(self, teksti, aika):
self.aika = aika
self.nayttotekstit.clear()
self.rivit.clear()
""" Teksti (str) ja aika (int) miten pitkään tekstiä näytetään """
self.nayttotekstit = [teksti[y-self.nayttoleveys:y] for y in range(self.nayttoleveys,
len(teksti)+self.nayttoleveys, self.nayttoleveys)]
for y in range(len(self.nayttotekstit)):
self.rivit.append(self.nayttotekstit[y])
if len(self.rivit) > self.nayttorivit:
sivuja = len(self.nayttotekstit) // self.nayttorivit
sivuja = 1
if sivuja == 1:
for z in range(0, len(self.rivit)):
self.naytto.text(self.rivit[z], 0, 1 + z * 10, 1)
async def teksti_riville(self, teksti, rivi, aika):
self.aika = aika
""" Teksti (str), rivit (int) ja aika (int) miten pitkään tekstiä näytetään """
if len(teksti) > self.nayttoleveys:
self.naytto.text('Rivi liian pitka', 0, 1 + rivi * 10, 1)
elif len(teksti) <= self.nayttoleveys:
self.naytto.text(teksti, 0, 1 + rivi * 10, 1)
async def aktivoi_naytto(self):
self.naytto.sleep(False)
self.naytto.show()
await asyncio.sleep(self.aika)
self.naytto.sleep(True)
async def kontrasti(self, kontrasti=255):
if kontrasti > 1 or kontrasti < 255:
self.naytto.contrast(kontrasti)
async def kaanteinen_vari(self, kaanteinen=False):
self.kaanteinen = kaanteinen
self.naytto.invert(kaanteinen)
async def kaanna_180_astetta(self, kaanna=False):
self.naytto.rotate(kaanna)
async def piirra_kehys(self):
if self.kaanteinen is False:
self.naytto.framebuf.rect(1, 1, self.pikselit_leveys-1, self.pikselit_korkeus-1, 0xffff)
self.naytto.framebuf.rect(1, 1, self.pikselit_leveys - 1, self.pikselit_korkeus - 1, 0x0000)
async def piirra_alleviivaus(self, rivi, leveys):
rivikorkeus = self.pikselit_korkeus / self.nayttorivit
alkux = 1
alkuy = 8 + (int(rivikorkeus * rivi))
merkkileveys = int(8 * leveys)
self.naytto.framebuf.hline(alkux, alkuy, merkkileveys, 0xffff)
self.naytto.framebuf.hline(alkux, alkuy, merkkileveys, 0x0000)
async def resetoi_naytto(self):
self.naytto.reset()
class KaasuSensori():
def __init__(self, i2cvayla=0, scl=22, sda=21, taajuus=400000, osoite=90):
self.i2c = I2C(i2cvayla, scl=Pin(scl), sda=Pin(sda), freq=taajuus)
self.laiteosoite = osoite
self.sensori = ccs811.CCS811(self.i2c)
self.eCO2 = 0
self.tVOC = 0
async def lue_arvot(self):
if self.sensori.data_ready():
self.eCO2 = self.sensori.eCO2
self.tVOC = self.sensori.tVOC
def ratkaise_aika():
(vuosi, kuukausi, kkpaiva, tunti, minuutti, sekunti, viikonpva, vuosipaiva) = utime.localtime()
paivat = {0: "Ma", 1: "Ti", 2: "Ke", 3: "To", 4: "Pe", 5: "La", 6: "Su"}
kuukaudet = {1: "Tam", 2: "Hel", 3: "Maa", 4: "Huh", 5: "Tou", 6: "Kes", 7: "Hei", 8: "Elo",
9: "Syy", 10: "Lok", 11: "Mar", 12: "Jou"}
#.format(paivat[viikonpva]), format(kuukaudet[kuukausi]),
paiva = "%s.%s.%s" % (kkpaiva, kuukausi, vuosi)
kello = "%s:%s:%s" % ("{:02d}".format(tunti), "{:02d}".format(minuutti), "{:02d}".format(sekunti))
return paiva, kello
async def neiti_aika():
print("Uptime %s" % utime.time())
await asyncio.sleep_ms(100)
esp32.hall_sensor()
async def main():
naytin = SPI_naytonohjain()
kaasusensori = KaasuSensori()
# tyojono = asyncio.get_event_loop()
""" asyncio.create_task(naytin.pitka_teksti_nayttoon("Pitka teksti nayttoon", 5))
asyncio.create_task(naytin.teksti_riville("Riville 3", 3, 10))
asyncio.create_task(naytin.pitka_teksti_nayttoon("Viela pidempi teksti nayttoon", 5)) """
asyncio.create_task(neiti_aika())
# Luetaan arvoja taustalla
asyncio.create_task(kaasusensori.lue_arvot())
# await naytin.pitka_teksti_nayttoon("Ilmanlaatumonitorointi v0.01", 5)
# await naytin.piirra_kehys()
await naytin.teksti_riville("PVM: %s" % ratkaise_aika()[0], 0, 5)
await naytin.teksti_riville("KLO: %s" % ratkaise_aika()[1], 1, 5)
if kaasusensori.eCO2 > 1:
await naytin.teksti_riville("eCO2: %s" % kaasusensori.eCO2, 3, 5)
if kaasusensori.eCO2 > 1000:
await naytin.kaanteinen_vari(True)
await naytin.kaanteinen_vari(False)
if kaasusensori.tVOC > 1:
await naytin.teksti_riville("tVOC: %s" % kaasusensori.tVOC, 4, 5)
if kaasusensori.tVOC > 500:
await naytin.teksti_riville("Hall: %s" % esp32.hall_sensor(),5,5)
await naytin.aktivoi_naytto()
# await naytin.piirra_alleviivaus(3, 7)
asyncio.run(main())
