I'm trying to make a simple http server, that should also be not blocking, allowing to handle other stuff.
Using IExploer i works quite well.
My problem is that Chrome, opens multiple tcp conenctions (at least 2):
- on one connection it sends the actual http request
- on the other one, it simply opens a tcp connection, without sending anything: that make python script stucked in socket.readline (same for socket.recv)
Here's the main code for socket handling
import usocket as socket
except:
import socket
from machine import Timer,Pin
def init_network():
gc.mem_free()
ssid="YYYYYYY"
password = 'XXXXXX'
station = network.WLAN(network.STA_IF)
station.active(True)
station.connect(ssid, password)
c=0
while station.isconnected() == False:
print ("init_network.. %d"%c, end="\r")
time.sleep_ms(1000)
c+=1
print('\nConnection successful: ',end="")
print(station.ifconfig())
s = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
s.bind(('', 80))
s.listen(5)
#gc.mem_free()
return s
def web_page():
if led.value() == 1:
gpio_state="ON"
gpio_state="OFF"
html = """<html><head> <title>ESP Web Server</title> <meta name="viewport" content="width=device-width, initial-scale=1">
<link rel="icon" href="data:,"> <style>html{font-family: Helvetica; display:inline-block; margin: 0px auto; text-align: center;}
h1{color: #0F3376; padding: 2vh;}p{font-size: 1.5rem;}.button{display: inline-block; background-color: #e7bd3b; border: none;
border-radius: 4px; color: white; padding: 16px 40px; text-decoration: none; font-size: 30px; margin: 2px; cursor: pointer;}
.button2{background-color: #4286f4;}</style></head><body> <h1>ESP Web Server</h1>
<p>GPIO state: <strong>""" + gpio_state + """</strong></p><p><a href="/?led=on"><button class="button">ON</button></a></p>
<p><a href="/?led=off"><button class="button button2">OFF</button></a></p></body></html>"""
return html
led = Pin(2, Pin.OUT)
s = init_network()
#s.settimeout(0.5)
import uselect as select
p = select.poll()
p.register(s,select.POLLOUT | select.POLLIN)
print ("Waiting connections..")
res = p.poll()
for sock, ev in res:
if ev & select.POLLIN:
client_sock, addr = s.accept()
except OSError as e:
print (e)
continue
print('Got a connection from %s' % str(addr))
client_stream = client_sock.makefile("rwb")
request = str(client_stream.readline())
print(request)
h = client_stream.readline()
print (" %s"%str(h))
if h == b"" or h == b"\r\n":
break
response = web_page()
print ("Sending")
r='HTTP/1.1 200 OK\n'
r+='Content-Type: text/html\n'
r+='Connection: close\n\n'
r+=response
sent=client_stream.write(r)
print ("Sent %d bytes"%sent)
client_stream.close()
except Exception as e:
print(str(e))
connection on 52049 is correctly handled, but the other one (52050), make script blocked (until Chrome ask a new page), but that make the esp32 blocked (e.g. timer don't work and neither socket connections from other clients are not handled)
init_network..
Connection successful: ('192.168.1.10', '255.255.255.0', '192.168.1.1', '192.168.1.1')
Got a connection from ('192.168.1.7', 52049)
b'GET / HTTP/1.1\r\n'
b'Host: 192.168.1.10\r\n'
b'Connection: keep-alive\r\n'
b'Cache-Control: max-age=0\r\n'
b'Upgrade-Insecure-Requests: 1\r\n'
b'User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/86.0.4240.198 Safari/537.36\r\n'
b'Accept: text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.9\r\n'
b'Accept-Encoding: gzip, deflate\r\n'
b'Accept-Language: it-IT,it;q=0.9,en-US;q=0.8,en;q=0.7\r\n'
b'\r\n'
Sending
Sent 839 bytes
Got a connection from ('192.168.1.7', 52050)
