UPDATE 20.01.2020: I added crc_errors and range_errors to the MHZ19_AS.py class and in this video https://youtu.be/wdhZWGnmWlU I demonstrate the problem:Divergentti wrote: ↑Tue Jan 19, 2021 9:38 pmThank you for heads up.marcidy wrote: ↑Tue Jan 19, 2021 7:15 pmDivergentti wrote: ↑Sun Jan 17, 2021 1:20 pmfor some reason after power on boot returned bytearray is like bytearray(b'\x00\x00\xa2\xff\x86\x01\x9a=\x00') but when UART works it is like bytearray(b'\xff\x86\x01\xfd=\x00\x00\x00?') where first FF is the key for proper reading.
That looks like noise, \xff\x86\x01 is there in both cases. Leading \x00 can be that the connected device isn't powered up yet, pulling down the lines and triggering a phantom transfer.Code: Select all
b'\x00\x00\xa2\xff\x86\x01\x9a=\x00' b'\xff\x86\x01\xfd=\x00\x00\x00
Do you have external pull-ups? Can you (electrically) enable the sensors after initializing the UART? This probably not a code / micropython issue but an electrical issue. If you can't do anything else, you can read bytes in a loop till you get \xff on initialization.
It's good to have sensible hardware defaults via pull-ups, and control the start-up and initialization of connected devices whenever possible. If you have access to the pins, you might want to add some external pull-ups to RX and TX.
It indeed looks like a noise and perhaps I shall add error frame counter to the MHZ19_AS.py class. If checksum from UART bytearray is wrong, counter increases. Noise is possible, because chip is SMD chip in the programming board and I use dupont connectors, which are bad. I am not using pullups, because I understood ESP32 has pullups as default and if I would like to use open drain GPIO, I have to turn them off? At least I have done so for circuits which are "grounding" through GPIO pin.
But then the but: this problem can be repeated without any changes to the hardware (= noise theory do not apply). With deletion of the sensor object everything works robust without errors (tested over night), but if I do not delete the sensor object as in the code I do, nothing works after power on boot, but works fine with soft boot.
- UART2 re-creation is disabled in the main.py code
- first boot is soft boot and as you see, everything works fine
- second boot is power on boot and you see that UART2 (= MHZ19_AS.py) related crc_errors start increasing each reading cycle and no CO2 values are read.
I hope this helps to find root cause for this problem.
