sdcard doesn't work with SoftSPI
FakirMaker
Post by FakirMaker » Mon Jan 18, 2021 7:14 pm
Hello today i have built the latest firmware with my custom modules and upload my esp32, however the regular sd card module started not to work. When i tried to use it as it was tomorrow i got an error :
Warning: SPI(-1, ...) is deprecated, use SoftSPI(...) instead
and i used
import sys
from machine import SoftSPI,Pin
import sdcard
import uos
spi =SoftSPI(baudrate=1000000,polarity=1,phase=0,sck=Pin(18),mosi=Pin(5),miso=Pin(19))
sd = sdcard.SDCard(spi,Pin(23))
uos.mount(sd,"/sd")
i got this error
File "sd.py", line 8, in <module>
which means
cannot initialize.
Is it about the SoftSPI or sdcard module?
thanks
Re: sdcard doesn't work with SoftSPI
Post by Roberthh » Mon Jan 18, 2021 8:08 pm
It may also be of SD cards. Micropyton is a little bit picky about SD card. They have to be formatted with a single FAT32 partition. Brand new SD cards are sometimes formatted differently. I had good experience with Samsung, Transcend and Sandisk cards in sizes of 8, 16, and 32 GB. And try to a) insert the card first, then b) push reset, then c) attempt to mount it, at least for initial testing.
FakirMaker
Post by FakirMaker » Tue Jan 19, 2021 9:47 pm
Thanks for reply Robert, the problem is caused by my board's design. Some genius people created a disaster. They confused my hardware pins and also added a led to pin 5 :) I finally solved the problem by myself in case somebody using TTGO T2 board with onboard SD card socket and SSD1331 display faces this problem in the future just use:
spi =SPI(1,baudrate=500000,polarity=0,phase=0,sck=Pin(18),mosi=Pin(5),miso=Pin(19))
