how to debounce these interrupts
mahmoud yassin
Post by mahmoud yassin » Fri Jan 22, 2021 5:38 am
from time import sleep
  import usocket as socket
except:
  import socket
import esp
esp.osdebug(None)
import gc
gc.collect()
ssid = 'ESP32-AP-WebServer'
password = '123456789'
ap = network.WLAN(network.AP_IF)
ap.active(True)
ap.config(essid=ssid, password=password)
while not ap.active():
    pass
print('network config:', ap.ifconfig())
# output pins
segA = Pin(23, Pin.OUT)
segB = Pin(22, Pin.OUT)
segC = Pin(33, Pin.OUT)
segD = Pin(13, Pin.OUT)
segE = Pin(21, Pin.OUT)
segF = Pin(19, Pin.OUT)
segG = Pin(18, Pin.OUT)
# input pins
button1 = Pin(36, Pin.IN)  # increment
button2 = Pin(34, Pin.IN)  # decrement
button3 = Pin(35, Pin.IN)  # reset
segments = [segA, segB, segC, segD, segE, segF, segG]  # assigning pins to arrary to ease addressing in loops
seven = [0b0111111, 0b0000110, 0b1011011, 0b1001111, 0b1100110, 0b1101101, 0b1111101, 0b0000111, 0b1111111, 0b1101111] #Binary values of seven segment numbers
global current_number
current_number = 0  # Default 7-segment value
s = socket.socket(socket.AF_INET, socket.SOCK_STREAM)  # server socket
s.bind(('',80)) # specifies that the socket is reachable by any address the machine happens to have
s.listen(5)     # max of 5 socket connections
# functions
def increment(self):
  sleep(.3)
  if current_number == 9 :
    current_number=0
  else :
    current_number = current_number+1
  for i in range(7):
     segments[i].value(seven[current_number]>>i & 1)
def decrement(self):
  sleep(.3)
  if current_number == 0 :
    current_number=9
  else :
    current_number = current_number-1
  for i in range(7):
def reset(self):
  sleep(.1)
  current_number = 0
  for i in range(7):
def seven_seg(current_number, button):
    if button == 1:
        sleep(.3)
          current_number=0
        else :
    elif button == 2 :
        sleep(.3)
          current_number=9
        else :
    elif button == 0:
        sleep(.1)
        current_number = 0
    return current_number
def web_page(current_number):
    print('7-segment is at ' + str(current_number))
    html = """<!DOCTYPE HTML>
        <html>
        <head>
          <meta name="viewport" content="width=device-width, initial-scale=1">
        </head>
        <body>
           <center><h2>ESP32 Web Server in MicroPython </h2></center>
           <center>
             <form>
               <button type='submit' name="SEVEN" value='1'> INCREASE</button>
               <button type='submit' name="SEVEN" value='2'> DECREASE</button>
               <button type='submit' name="SEVEN" value='0'> RESET</button>
             </form>
           </center>
           <center><p>seven segment is at <strong>""" + str(current_number) + """</strong>.</p></center>
           <center><p>PRESS ANY BUTTON <strong></strong>.</p></center>
        </body>
        </html>"""
    return html
#Defining external interrupt pins
button1.irq(trigger=Pin.IRQ_FALLING , handler = increment)
button2.irq(trigger=Pin.IRQ_RISING , handler = decrement)
button3.irq(trigger=Pin.IRQ_RISING , handler = reset)
    for i in range(7):
    conn, addr = s.accept()
    print("Got connection from %s" % str(addr))
    # Socket accept()
    # Socket receive()
    request=conn.recv(1024)
    print("")
    print("")
    print("Content %s" % str(request))
    # Socket send()
    request = str(request)
    check = request.find('/?SEVEN')
    if check == 6:
        print(str(check))
        current_number = seven_seg(current_number,int(request[14]))
    response = web_page(current_number)
    conn.send('HTTP/1.1 200 OK\n')
    conn.send('Content-Type: text/html\n')
    conn.send('Connection: close\n\n')
    conn.sendall(response)
    # Socket close()
    conn.close()
Re: how to debounce these interrupts
Post by pythoncoder » Fri Jan 22, 2021 9:25 am
I use uasyncio with this debouncer rather than using interrupts.
