What the best IDE for ESP32 micro python developing ?
Tell me please what IDE you use for ESP32 micro python developing ?
Thony, uPyCraft, PyCharm or VSCode + some plugin or something else.
Is it possible to debug python source code at all ?
Re: What the best IDE for ESP32 micro python developing ?
Everybody use linux + nano editor + command line for uploading as I do ?
so, I share own method
add to the ~/bashrc EOF string
source ~/esp_upload.sh
Hint: dont forget logout/logit to take effect
esp_upload.sh
For example i modified sys_info.py in project directory ~/mpy-vRelay/src/Inc
then upload file to board with command
enter terminal
>esp
copy files to device and enter terminal
>esp dev_dht22.py dev_sht31.py
>espf dev_dht22.py dev_sht31.py
copy files to device from current directory
>espd
to exit from picocom
Ctrl+A+X
esp_upload.sh
#!/bin/bash
#VladVons, 2021.01.25
#add to ~/bashrc EOF source ~/esp_upload.sh and logout/logit to take effect
#to exit from picocom Ctrl+A+X
#### enter terminal
#esp
##### send files to device and ener terminal
#esp dev_dht22.py dev_sht31.py
#espf dev_dht22.py dev_sht31.py
##### send files from current directory to device
#espd
##### receive files from device from current directory
#espg
cSpeed=115200
cPort=/dev/ttyUSB0
_esp_install()
sudo pip3 install esptool
sudo pip3 install adafruit-ampy
sudo pip3 install picocom
# add current user preveleges
sudo usermod -a -G dialout $USER
sudo usermod -a -G tty $USER
_esp_terminal()
picocom $cPort -b${cSpeed}
_esp_file_transfare()
aMode=$1; aFile=$2;
Path="$(pwd)/$aFile"
Find="src"
Suffix=${Path#*$Find}
if [ "$aMode" == "put" ]; then
Cmd="ampy --port $cPort --baud $cSpeed put $aFile $Suffix"
elif [ "$aMode" == "get" ]; then
Cmd="ampy --port $cPort --baud $cSpeed get $Suffix"
else
Cmd="echo unknown mode $aMode"
fi
echo $Cmd
eval "$Cmd"
espg()
for File in $*; do
_esp_file_transfare get $File
done
##### send files to device from current directory
espd()
for File in $(ls -1); do
_esp_file_transfare put $File
done
espf()
for File in $*; do
done
##### send files to device and enter terminal
esp()
aFile=$1;
if [ -z "$aFile" ]; then
_esp_terminal
else
killall picocom
espf $*
_esp_terminal
fi
enter terminal
>esp
>espd
Ctrl+A+X
I use Sublime Text, but the actual editor doesn't matter too much. I just want something fast and lightweight with basic navigation features and emacs shortcuts.
Then for testing the code on the board I use pyboard.py and miniterm. The key thing about pyboard.py, especially during development, is that you don't have to copy the code to the device first, you can just "run this file". http://docs.micropython.org/en/latest/r ... rd.py.html
There's a new tool that should be available soon called "mpr" (see https://github.com/micropython/micropython/pull/6375) which allows you to mount the PC's filesystem onto the MicroPython device, which means you can skip the file copy step even for multi-file projects.
Unfortunately no. You can debug the C code (using JTAG on ESP32 or SWD/JTAG on ARM), which is often useful enough to track down what's going on.
However, I generally try to avoid actually developing testing the code on the device. Either I use CPython or the unix port of MicroPython with the a mock implementation of the hardware bits.
Interesting. I think whether to debug on the hardware depends on what you're developing. I use the same approach for developing algorithms which don't use the hardware, using the Unix build of MicroPython.
But most of the things I do are hardware dependent, such as writing device drivers, sometimes for weird bits of kit like 433MHz radios. I use Kate for the editor, but as @jimmo says this is purely down to personal choice. I use this fork of Dave Hylands rshell for copying files to the device and running the REPL (the fork adds text macros which are seriously useful for complex projects). I debug the old fashioned way with print statements.
In my view debugging on the hardware doesn't slow things down much once you establish a good workflow, but mileage varies. But mpr does sound interesting and could speed development while running the code on the hardware.
I've tried one or two IDE's but I was unconvinced they offered much, although they are great for beginners. There is no MicroPython debugger, sadly, otherwise my view of IDE's might be very different.
- aivarannamaa
The problem is that currently it's not possible to query locals at debug time. I just added a feature request for this: https://github.com/micropython/micropython/issues/6799. Feel free to vote for it!pythoncoder wrote: ↑Tue Jan 26, 2021 6:30 amThere is no MicroPython debugger, sadly, otherwise my view of IDE's might be very different.
Aivar Annamaa
https://thonny.org
https://thonny.org
Is this the only roadblock? Does an underlying mechanism exist to support single stepping and code breakpoints?aivarannamaa wrote: ↑Tue Jan 26, 2021 6:56 am...
I could become a Thonny user if we can debug!
- aivarannamaa
Since 1.12 it is possible to compile MicroPython with sys.settrace, which can be used for registering a callback function to be called by the VM when a frame is entered/exited, exception raised or a new line reached. The callback function gets information about current stack (but not locals). It seems to work quite like sys.settrace in CPython. I've experimented with it only in the Unix port, though, but I expect it to work in bare metal ports as well.pythoncoder wrote: ↑Tue Jan 26, 2021 1:51 pmIs this the only roadblock? Does an underlying mechanism exist to support single stepping and code breakpoints?
Aivar Annamaa
https://thonny.org
https://thonny.org
Excellent. A debugger would be a real game-changer.
I use VSCode to develop micropython applications.
On top of that I use the micropy-cli which installs the stubs for micropython (https://github.com/BradenM/micropy-cli)
The stubs are useful as the Pylance language server won't complain if e.g. you `import esp32` and all the functions and constants are defined in the stubs. So if I want to know e.g. the wakeup reasons I can just type esp. and then tab and it will show all the globals int he esp32 module.
For me the biggest advantage of VSCode is the markdown plugin which I use to document things on the side (not in the python files but in separate markdown files).
Most of the time I run the application using the pyboard command without copying it over.
To copy the application, libraries and config files I have a set of make command, e.g. `make deploy-dependencies` or `make deploy-configs` which just call the pyboard command again.
For debugging I use print statements.
What mock implementation of the hardware bits do you use? I'm fairly new to MicroPython and trying to figure out this side of it. Do you use https://github.com/Josverl/micropython-stubs, your own set of stubs or something else?
Thanks.
