Micropython V1.14 Problem
Posted: Mon Feb 08, 2021 9:28 pm
by joker12
I've been using Micropython v1.13 for some time and use webrepl to program the board using Thonny v3.3.3.
This is the code in my boot.py:
import esp
esp.osdebug(None)
wlan.active(True)
wlan.connect('xxxxx', 'xxxxx')
wlan.isconnected()
import webrepl
webrepl.start()
I uploaded Micropython v1.14 and set it up the same way and enabled webrepl. The board crashes when it reaches wlan.active(True).
Has anyone else had a problem with the new version?
I reverted back to 1.13 and everything is fine again.
Re: Micropython V1.14 Problem
Posted: Wed Feb 10, 2021 9:01 pm
by marcidy
I'd would be helpful if you add details of the crash from the console.
And if the debug level doesn't impact the crash, I'd suggest raising it.
If it's a brownout, you need to provide more power.
Posted: Thu Feb 11, 2021 12:23 am
by joker12
Thanks for the reply.
I've installed version 1.14 on 3 ESP32's.
Tried running webrepl in Thonney with the following result on each one:
WebREPL connected
Exception in thread Thread-1:
File "D:\Users\xxx\AppData\Local\Programs\Thonny\lib\site-packages\websockets\protocol.py", line 827, in transfer_data
message = await self.read_message()
File "D:\Users\xxx\AppData\Local\Programs\Thonny\lib\site-packages\websockets\protocol.py", line 910, in read_message
return frame.data.decode("utf-8") if text else frame.data
UnicodeDecodeError: 'utf-8' codec can't decode byte 0x80 in position 0: invalid start byte
The above exception was the direct cause of the following exception:
File "D:\Users\xxx\AppData\Local\Programs\Thonny\lib\threading.py", line 926, in _bootstrap_inner
self.run()
File "D:\Users\joker\AppData\Local\Programs\Thonny\lib\threading.py", line 870, in run
self._target(*self._args, **self._kwargs)
File "D:\Users\xxx\AppData\Local\Programs\Thonny\lib\site-packages\thonny\plugins\micropython\webrepl_connection.py", line 54, in _wrap_ws_main
loop.run_until_complete(self._ws_main())
File "D:\Users\xxx\AppData\Local\Programs\Thonny\lib\asyncio\base_events.py", line 587, in run_until_complete
return future.result()
File "D:\Users\xxx\AppData\Local\Programs\Thonny\lib\site-packages\thonny\plugins\micropython\webrepl_connection.py", line 66, in _ws_main
await asyncio.gather(self._ws_keep_reading(), self._ws_keep_writing())
File "D:\Users\xxx\AppData\Local\Programs\Thonny\lib\site-packages\thonny\plugins\micropython\webrepl_connection.py", line 123, in _ws_keep_writing
await self._ws.send(payload)
File "D:\Users\xxx\AppData\Local\Programs\Thonny\lib\site-packages\websockets\protocol.py", line 555, in send
await self.ensure_open()
File "D:\Users\xxx\AppData\Local\Programs\Thonny\lib\site-packages\websockets\protocol.py", line 812, in ensure_open
raise self.connection_closed_exc()
websockets.exceptions.ConnectionClosedError: code = 1006 (connection closed abnormally [internal]), no reason
It looks like something in Thonny is broken by the new version.
Power is fine.
I then reinstall version 1.13 and it always works:
WebREPL connected
>>> MicroPython v1.13 on 2020-09-02; ESP32 module with ESP32
Posted: Fri Feb 12, 2021 11:13 am
by bertel
Thonny 3.3.3:
Initializing Wifi
WebREPL daemon started on ws://192.168.73.69:8266
Started webrepl in normal mode
network config: ('192.168.73.69', '255.255.255.0', '192.168.73.1', '192.168.73.1')
Free mem: 3.90155 MB
Flash size: 16.0 MB
Free flash: 13.98828 MB
MicroPython v1.14-13-gdf85e4881-dirty on 2021-02-12; ESP32 module (spiram) with ESP32
Posted: Wed Feb 17, 2021 11:28 am
by aivarannamaa
Joker, this problem has been reported at
https://github.com/micropython/micropython/issues/6912.
Next Thonny version (hopefully released by the end of this week) will include a work-around.
Posted: Thu Feb 18, 2021 8:52 am
by aivarannamaa
Thonny 3.3.4 is now released, including the work-around regarding the WebREPL issue in MicroPython 1.14:
https://github.com/thonny/thonny/releases/tag/v3.3.4
Posted: Tue Feb 23, 2021 8:09 am
by aivarannamaa
A regression was introduced in Thonny 3.3.4 (object evaluation in the REPL gave too short capped repr-s). A fix is now published in 3.3.5:
https://github.com/thonny/thonny/releases/tag/v3.3.5
Posted: Sun Mar 07, 2021 10:19 pm
by joker12
Thanks for the update. I now know I'm sane?
