Cannot get a response from BLE scan
pluviofeel
Post by pluviofeel » Mon Feb 15, 2021 2:59 am
Dear Community;
It's my first post and I am new to ESP32&micropython.
I am using ESP32 to build a bluetooth network recently, but I cannot get any response from _IRQ_SCAN_RESULT.
The first method is this:
from micropython import const
import ubluetooth
ble=ubluetooth.BLE()
if ble.active()== False:
    ble.active(True)
print(ble.active())
_IRQ_SCAN_RESULT                     = const(1 << 4)
_IRQ_SCAN_COMPLETE                   = const(1 << 5)
def adv_decode(adv_type, data):
    i = 0
    while i + 1 < len(data):
        if data[i + 1] == adv_type:
            return data[i + 2:i + data[i] + 1]
        i += 1 + data[i]
    return None
def adv_decode_name(data):
    n = adv_decode(0x09, data)
    if n:
        return n.decode('utf-8')
    return data
def bt_irq(event, data):
    if event == _IRQ_SCAN_RESULT:
        # A single scan result.
        addr_type, addr, connectable, rssi, adv_data = data
        print(addr_type, addr, adv_decode_name(adv_data))
    elif event == _IRQ_SCAN_COMPLETE:
        # Scan duration finished or manually stopped.
        print('scan complete')
ble.irq(handler=bt_irq)
# Scan for 10s (at 100% duty cycle)
ble.gap_scan(10000, 30000, 30000)
And I just got a "True"
The second option is the following:
import ubluetooth
import utime
_IRQ_CENTRAL_CONNECT                 = const(1 << 0)
_IRQ_CENTRAL_DISCONNECT              = const(1 << 1)
_IRQ_GATTS_WRITE                     = const(1 << 2)
_IRQ_GATTS_READ_REQUEST              = const(1 << 3)
_IRQ_PERIPHERAL_CONNECT              = const(1 << 6)
_IRQ_PERIPHERAL_DISCONNECT           = const(1 << 7)
_IRQ_GATTC_SERVICE_RESULT            = const(1 << 8)
_IRQ_GATTC_CHARACTERISTIC_RESULT     = const(1 << 9)
_IRQ_GATTC_DESCRIPTOR_RESULT         = const(1 << 10)
_IRQ_GATTC_READ_RESULT               = const(1 << 11)
_IRQ_GATTC_WRITE_STATUS              = const(1 << 12)
_IRQ_GATTC_NOTIFY                    = const(1 << 13)
_IRQ_GATTC_INDICATE                  = const(1 << 14)
    ble.active(True)
print(ble.active())
def form_mac_address(addr: bytes) -> str:
    return ":".join('{:02x}'.format(b) for b in addr)
print("BLE current mac address: {}".format(form_mac_address(ble.config("mac"))))
    if event == _IRQ_CENTRAL_CONNECT:
        # A central has connected to this peripheral.
        conn_handle, addr_type, addr = data
    elif event == _IRQ_CENTRAL_DISCONNECT:
        # A central has disconnected from this peripheral.
    elif event == _IRQ_GATTS_WRITE:
        # A central has written to this characteristic or descriptor.
        conn_handle, attr_handle = data
    elif event == _IRQ_GATTS_READ_REQUEST:
        # A central has issued a read. Note: this is a hard IRQ.
        # Return None to deny the read.
        # Note: This event is not supported on ESP32.
    elif event == _IRQ_SCAN_RESULT:
        print('type:{} addr:{} rssi:{} data:{}'.format(addr_type, ubinascii.hexlify(addr), rssi, ubinascii.hexlify(adv_data)))
        pass
    elif event == _IRQ_PERIPHERAL_CONNECT:
        # A successful gap_connect().
    elif event == _IRQ_PERIPHERAL_DISCONNECT:
        # Connected peripheral has disconnected.
    elif event == _IRQ_GATTC_SERVICE_RESULT:
        # Called for each service found by gattc_discover_services().
        conn_handle, start_handle, end_handle, uuid = data
    elif event == _IRQ_GATTC_CHARACTERISTIC_RESULT:
        # Called for each characteristic found by gattc_discover_services().
        conn_handle, def_handle, value_handle, properties, uuid = data
    elif event == _IRQ_GATTC_DESCRIPTOR_RESULT:
        # Called for each descriptor found by gattc_discover_descriptors().
        conn_handle, dsc_handle, uuid = data
    elif event == _IRQ_GATTC_READ_RESULT:
        # A gattc_read() has completed.
        conn_handle, value_handle, char_data = data
    elif event == _IRQ_GATTC_WRITE_STATUS:
        # A gattc_write() has completed.
        conn_handle, value_handle, status = data
    elif event == _IRQ_GATTC_NOTIFY:
        # A peripheral has sent a notify request.
        conn_handle, value_handle, notify_data = data
    elif event == _IRQ_GATTC_INDICATE:
        # A peripheral has sent an indicate request.
ble.irq(bt_irq)
ble.gap_scan(20000)
With this method I am not getting any error but only the mac address...
Please any help or suggestion is highly appreciated.
Thanks a lot,
Pluvio.
Re: Cannot get a response from BLE scan
Post by jimmo » Mon Feb 15, 2021 3:29 am
It looks like you might be using sample code from an older version of the bluetooth API (it was marked as experimental for this reason, although it's starting to stabilise now). Assuming you're using MicroPython 1.13 or 1.14, then please see https://docs.micropython.org/en/latest/ ... tooth.html
In particular, the constants for the event types has changed.
_IRQ_CENTRAL_CONNECT = const(1)
_IRQ_CENTRAL_DISCONNECT = const(2)
_IRQ_GATTS_WRITE = const(3)
_IRQ_GATTS_READ_REQUEST = const(4)
_IRQ_SCAN_RESULT = const(5)
_IRQ_SCAN_DONE = const(6)
_IRQ_PERIPHERAL_CONNECT = const(7)
_IRQ_PERIPHERAL_DISCONNECT = const(8)
_IRQ_GATTC_SERVICE_RESULT = const(9)
_IRQ_GATTC_SERVICE_DONE = const(10)
_IRQ_GATTC_CHARACTERISTIC_RESULT = const(11)
_IRQ_GATTC_CHARACTERISTIC_DONE = const(12)
_IRQ_GATTC_DESCRIPTOR_RESULT = const(13)
_IRQ_GATTC_DESCRIPTOR_DONE = const(14)
_IRQ_GATTC_READ_RESULT = const(15)
_IRQ_GATTC_READ_DONE = const(16)
_IRQ_GATTC_WRITE_DONE = const(17)
_IRQ_GATTC_NOTIFY = const(18)
_IRQ_GATTC_INDICATE = const(19)
_IRQ_GATTS_INDICATE_DONE = const(20)
_IRQ_MTU_EXCHANGED = const(21)
_IRQ_L2CAP_ACCEPT = const(22)
_IRQ_L2CAP_CONNECT = const(23)
_IRQ_L2CAP_DISCONNECT = const(24)
_IRQ_L2CAP_RECV = const(25)
_IRQ_L2CAP_SEND_READY = const(26)
_IRQ_CONNECTION_UPDATE = const(27)
_IRQ_ENCRYPTION_UPDATE = const(28)
_IRQ_GET_SECRET = const(29)
_IRQ_SET_SECRET = const(30)
pluviofeel
Post by pluviofeel » Mon Feb 15, 2021 4:08 am
Thanks a lot!!!
It works right now(even though I don't understand what the concept is..
