https://github.com/wangshujun-tj/mpy-Framebuf-boost
Modify framebuf.c implementation
In addition to Chinese support, it also provides FB large character display, 8 megabyte / 16 megabyte flash precompile, and BMP file display and storage
Chinese enhanced firmware for framebuf components
Re: Chinese enhanced firmware for framebuf components
Alas I can't read the Chinese README, so I may be wrong. But this appears to be closed source. If so, this is a pity as framebuf enhancements are of general interest.
Probably this is the corresponding MIT-licensed source: https://github.com/wangshujun-tj/mpy-Fr ... boost-code
I don't know the rules of open source very well. I'm willing to share the code that needs to be modified
The Chinese font library comes from the font library of windows system. It is captured after displaying the screen picture. It is not confirmed whether there is copyright conflict
Because most of the users who need Chinese display are Chinese users, they directly write Chinese information
For now, this change:
1. Replace a file framebuf. C
2. Add a header file of English font
In addition, we need to refer to the seek in stream. C. It is not clear whether it is the most reasonable choice to refer to this seek
Here is the demo code and video
https://github.com/wangshujun-tj/mpy-Fr ... st-ssd1306
The Chinese font library is downloaded from the file system. Without using Chinese, you can also get large English fonts, enlarge, rotate, and reverse
Firmware feature update
By adding 4-bit look-up table conversion function, TFT can be driven by 4-bit FB
The background color of character display is added. When the background color is 0, it remains transparent
Fixed RGB24 BMP display color error
Demo added
ST7567 monochrome LCD module 128x64 , esp8266+esp32 demo
Ssd1306 monochrome OLED module 128x64 , esp8266+esp32 demo
St7735 0.96 TFT module 80×160
St7789 1.14 TFT module 135×240
St7735 0.96 TFT 16color display module 80x160 , esp8266+esp32 demo
Demo added
This function is also normal when tested on stm32f407 board
The font files are stored in sdcard
The display speed is much faster than that of esp32
Rgb565 mode can support 128 × 160
The 16 color mode can support 320 × 240
