VL53L0X I2C sensor not recognized after machine.reset()
oserror
Post by oserror » Fri Mar 05, 2021 1:45 am
I have the ESP32 powered by a 12 Volt power supply -> buck converter -> 6 Volts to VIN and GND pins. The VL53L0X is powered by the 3V3 pin of the ESP32.
When connected via WiFi over WebREPL, if I stop main.main() with CTRL-C and call:
machine.reset()
and reconnect, execution has halted. I find that the i2c instance has loaded but i2c.scan() produces an empty list.
Power cycling the device solves the problem. I hooked up a Tasmota power plug and just toggle it off and on to solve the issue for now to avoid running up and down the stairs.
Is there a problem with the i2c declaration? Mine looks like:
i2c = I2C(
    0,
    scl=Pin(config.SCL_PIN),
    sda=Pin(config.SDA_PIN),
    freq=400000
Also, is there any interest in my port of the Adafruit VL53L0X driver to MicroPython? I haven't put it up on GitHub yet but it seems to be working fine so far.
Thanks for any help!
oserror
Re: VL53L0X I2C sensor not recognized after machine.reset() - Now recognized
Post by oserror » Sat Mar 06, 2021 6:02 pm
Well, I cleaned up my networking code and now the sensor initializes as expected, most of the time.
Perhaps I was working the ESP32 too hard before? The "OSError: [Errno 19] ENODEV" error still occurs but not as often. I should have specified the error before. My apologies.
My real quibble now is that I think I chose the wrong sensor, as I need a smaller range than I initially thought. The sensor is detecting values from about 100mm to 130mm with about +/- 5mm resolution. I might try a VL6180X since that seems to be more in my range for this application.
This is for detecting water levels in a PVC pipe. The sensor is mounted to a test cap at the top of the vertical pipe.
oserror
Post by oserror » Sun May 09, 2021 11:40 am
I have been using this ported Adafruit driver for a while now, and it seems stable enough. I think it should be as I only changed the various CircuitPython calls to their MicroPython equivalents.
Here is the link to the ported driver:
https://github.com/truckershitch/micropython-vl53l0x
If anyone has an issue with it, please post an issue on GitHub as I don't always get an email from here (I probably have incorrect forum settings).
Thanks.
