This thing is weird. I had been using a module (AZDELIVERY ESp32), flashed it, and I was pushing python files without any issue using pyboard.py. At one moment this module became unresponsive, and I started getting this error:
python pyboard.py --device COM4 test.py
could not enter raw repl
1. I erased flash memory and reflashed it with esp32-idf4-20210202-v1.14.bin, erasing all the files (in case there was something stuck)
2. I tested in that module, again, and I can not even use uPyLoader or pyboard.py to push files...
3. I changed and tested different ports in my pc and microusb cables, just in case. Nothing.
4. So I changed to another module, brand new. Extracted from it's plastic bag. Erased memory, flashed the bin, and the same thing is happening. Which makes no sense. I don't know what to test anymore.
When I issue the "mode" command in Windows I get this: Which seems "ok" unless I am missing something.
Status for device COM4:
Baud: 115200
Parity: None
Data Bits: 8
Stop Bits: 1
Timeout: OFF
XON/XOFF: OFF
CTS handshaking: OFF
DSR handshaking: OFF
DSR sensitivity: OFF
DTR circuit: OFF
RTS circuit: OFF
