Copy script file to board
Terrence
Post by Terrence » Thu Aug 18, 2016 6:57 pm
I have just flashed my ESP8266 board from my Windows 10 PC.
How do I push my script file to the feather and have it run every time the board is started?
Thank you.
shaoziyang
Re: Copy script file to board
Post by shaoziyang » Fri Aug 19, 2016 2:01 am
You can using:
[*]webrepl_cli
[*]mpfshell
[*]uPyLoader
Post by pythoncoder » Fri Aug 19, 2016 5:58 am
I've mainly used webrepl http://docs.micropython.org/en/latest/e ... ive-prompt and mu http://forum.micropython.org/viewtopic.php?f=15&t=2182. The former works via a web browser and works whether the device is in station mode or access point mode. mu works via a USB serial connection.
To run your code at boot first debug your module at the REPL. Once you have a working module - say mymodule.py with a function run - create a file main.py with the following contents and copy it to the device.
import mymodule
mymodule.run()
Terrence
Post by Terrence » Fri Aug 19, 2016 1:54 pm
Thank you for that explanation @pythoncoder.
And @shaoziyang thank you for your suggestions.
